Results 1 to 9 of 9
Thread: Powering Xenarc
    Apr 2005
    Queens, New York
    Powering Xenarc
    Ok well i am trying to figure out the best way to power my xenarc. I believe every1 says to power it straight to the opus? Now if i do that what wires do i tap in at?
    Also people have connected there opus to an ITPS. In this link the 1st picture:
    http://www.logicsupply.com/faqdesk_i.../faqdesk_id/13
    is how to wire an ITPS for the mobo. Basically on the right side(where the dc-dc is) of the ITPS is where i would power my xenarc? or no?
    Low Bitrate jimothy's Avatar
    Oct 2004
    Northern VA
    I've been wondering the same thing. Based on what i've read, I think you can just wire the Xenarc with a Molex connector which can plug into the Opus. So I guess you can chop off the end of the power cord and re-wire that for a Molex connector?
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    that's what I did.
    Apr 2005
    Queens, New York
    Hey which connector is it the female or male?
    Elsewhere
    Male connectors have little pins sticking out. Think little penises (penii?).
    Female connectors have holes where the pins go. Think vaginas.
    How about the Wiki?
    Central NY
    I really didn't want to chop off my powercord, so I just bought a female cig. lighter adapter from walmart, connected it to a molex pass through cable which I removed from a bad cpu fan, so I didn't lose a molex power connector, and didn't have to damage the Xenarc cable. Make sure you use the 12V rail (yellow/black), but all my cpu fans were wired that way to start with, so it was a 5 minute job.
    Oct 2004
    Northern VA
    so i chopped off the Xenarc car adapter egg thingy, and it's got one wire inside another. So I'm guessing the one on the outside is the shield - do i use that for a ground? is there a special trick to doing that?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    you could always jsut get some cable and a power socket like the one on the Xenarc.
    I actually think Xenarc have their power the oposite ay round to most people (i THINK the +ve is on the outside). I would recommend checking the polarity with a multimeter or an LED and a resistor (use the wall plug adapter if you have already cut your cable)
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    Quote Originally Posted by electron
    I really didn't want to chop off my powercord.
    You don't have to. Just pop open the plastic housing and you can easily desolder the wires where they connect.
    I'm powering my Xenarc from the ITPS, not the case PSU.
    I'm really starting to wish I had gone with a Carnetix unit.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  1. Powering a Xenarc
    By is300 in forum Newbie
    Last Post: 02-24-2005, 09:54 PM
  2. powering xenarc 7"?
    By shiltz in forum LCD/Display
    Last Post: 01-20-2005, 08:07 PM
  3. Question: Powering Xenarc from Morex 80w?
    By eleventh in forum Power Supplies
    Last Post: 12-05-2004, 09:58 AM
  4. Strange problem powering xenarc from 90w Opus :(
    By Brettster in forum LCD/Display
    Last Post: 05-11-2004, 06:19 AM
  5. Powering Xenarc from an Opus?
    By Lytheum in forum Power Supplies
    Last Post: 03-22-2003, 08:50 PM
