Page 106 of 123 FirstFirst ... 65696979899100101102103104105106107108109110111112113114115116 ... LastLast
Results 1,051 to 1,060 of 1222
Thread: LCD Backlight Upgrade
  1. #1051
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by Dirk9N
    thats the reason why I was thinking about plexiglass (kind of plasic) thatwill spread the light, so yoou don't need that many LED's and the light distribution will be better.
    how high these will be isn't interesting me, because i will have about 20cm (~4/5") space behind my Xenarc and I got a cheap seller at egay.
    maybe the answer is here at the threat, but I haven't found, has anybody tested to spread the light with plexiglas
    Also, if you had a look inside the xenarc and had read anything on this htread you would know that the fragile cables between the LCD driver and the panel prevent you from using anthing thicker than the exisiting backlight. The lilliput is better as you can lay the driver PCB down if you do a molded in job but the xenarc also has a side ribbon. True you could get round this if you made an extension cable but that is not in keeping with this whole projects goals.
  2. #1052
    Newbie Dirk9N's Avatar
    Jul 2004
    Germany
    Quote Originally Posted by Scouse Monkey
    answers are all in this thread buddy.
    not gonna go through it all again as i have a headache!
    sorry, than i haven't seen it down the 70 pages
  3. #1053
    Oct 2004
    NY
    one thing I can add is that led's right up to the back of the lcd will be a problem with diffusion... that multi-led picture a few posts back looks like crap as far as dispersion & will need so much diffusion that in the end almost all the light will be blocked by the diffusers... it looks realy bright now, but thats because of lack of dispersion through diffusers.... from what I've seen with my led project you will defanatly need to back those led's away from the lcd to help
    I originally thought about using many many smaller led's, but the kind that don't heat up aren't bright enough.... you will loose almost 90% of the available light to diffusers to get an even pattern, so you REALLY need to light that sucker up...., unless your willing to accept hot spots scattered, which is what that looks like.....
    plexi will do nothing unless you sand it opaque, then it will blurr the hotspots, but also cut the available light down significantly.... from my experience I would say that to use led's you will need depth..... alot more than the original goals of this project will afford........
  4. #1054
    Mar 2004
    Bristol
    read it all! go on, i dare you!
    this thread is getting huge. regular LEDs are basically a bad idea for large screens (over cell-phone size). Industry has only just started using LEDs because of the new high power ones (>1W) like the luxeons that TC is using. Sony currently have a luxeon screen that does 800nit but is still indirect but shining the leds up into a curved reflector which then shines into a regular LCD liht guide (plexy type material with dimples on the back). This light guide takes light in at the edge and then whent he light hits a dimple on the back surface it changes direction and either comes out of the front straight through the LCD or out of the back and hits the white rear reflector and then passes back through the light guide and out through the LCD.
    Doing it this way they get round the problems with bright spots and they can cool the LEDS nicely round the back with finned heatsinks.
  5. #1055
    Mar 2004
    Bristol
    Quote Originally Posted by turbocad6
    that sounds as though you wanted to create a watercooled screen from the outset!
  6. #1056
    Oct 2004
    NY
    all I wanted from the outset was to be able to see my f@&*in' screen at all times.... I really didn't want to water cool a screen..... it just turned out that way
  7. #1057
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Hey guys cheaper way, move to northern england the suns not as bright over here.........
    Sorry..........
    Sounds like you needed a tension breaker, you really have been on this for ages and I think you deserve loads of respect for the time you have put in.
  8. #1058
    Quote Originally Posted by lez
    I did more the opposite but my car PC habit isn't enough to make me regret it...
  9. #1059
    Oct 2004
    NY
    here's the hold up with the led backlight..... the plumbing has turned into the biggest pain in the ***..... I can't sweat pipe to save my life!!!!! I almost threw this across the shop tonight..... I give up, tommorow I'm going to find a plumber to do this for me......... I've been screwing with this part of the project the longest & everything else has been easy compared to this!!!!!
    once the pipework is done I can put this in & finish it....
  10. #1060
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Nice Job (cough), no really, looks well planned out(plumbing wise), sorry to hear about the sweating prob that your having.
    I think that slowly I'm starting to get to that point where not being able to see my screen durring the day unless its an overcast day..is getting to me...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Replies: 13
    Last Post: 12-24-2005, 06:14 PM
  2. Anyone know how to upgrade brightness on LCD?
    By maxcosity in forum LCD/Display
    Last Post: 06-22-2005, 01:09 PM
  3. FS: Nec 10.4" LCD w/ Backlight Inverter
    By SuperMatty in forum Classified Archive
    Last Post: 06-07-2003, 12:21 PM
  4. Replies: 2
    Last Post: 07-16-2002, 09:15 PM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
