Thread: LCD Backlight Upgrade
  1. #1081
    Oct 2004
    NY
    theres damaged lillis popping up all the time also, finding one with a good ccfl shouldn't be that difficult
  2. #1082
    Underachiever ACHIEVER's Avatar
    Jul 2004
    Up in dat ass Ranking: Mr. 25,000!!! :) Posts: 10000 +
    Quote Originally Posted by Scouse Monkey
    I have never even touched a lilliput screen!
    I knew you were smarter than you look!
  3. #1083
    Oct 2004
    NY
    almost there......
  4. #1084
    Oct 2004
    NY
    I found a 6.4" lcd that is 800 nit.... I'm going to get one of these..... only drawback with it is it's 640X480....I want to use it as an auxilary screen..... I'll be able to compare this 800 nit with the led screen...... I hope the led screen is as bright as this....
    that 6.4" is around $450 with the controller...touch is available, but not included at that price...... looks like a good option as far as bright screens are concerned I think.... maybe a little on the small side as a primary screen, but maybe not so bad either....
  5. #1085
    Maximum Bitrate MaleBuffy's Avatar
    Aug 2003
    Greece
    Quote Originally Posted by turbocad6
    Why not reverse engineer your new 800 nit screen so that you can aplly the brightness to existing ones? See how its done and all that...
  6. #1086
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
  7. #1087
    Mar 2004
    Bristol
    Quote Originally Posted by MaleBuffy
    that is effectively what we are doing. Only we designed the mod and then found out it is exactly the same way as current high brightness leds!!! so we are ont he right track.
    You hvae to understand that the real manufacturers have:
    1. the ability to get the right polarizers etc etc made - we dont
    2. Ditto with the diffusers
    3. They can afford to get custom LEDs made as they deal in bulk
    4. They then charge a **** load for their daylight viewable screens - much more than your screen + our kit will cost.
    5. if it ever needs repairing you got a hell of a job and will most liekly have to buy a new screen (thats why i prefer DIY/kits)
    EDIT: pic not aimed at you btw, just felt compelled to post it as I just got sent it.
  8. #1088
    Oct 2004
    NY
    it's a dual bulb setup...... probably uses larger bulbs & is probably a bit thicker than a standard lcd.... like scouse said, I'm sure the polarizers, deflectors & diffusers are optimized, as well as the light guide(s)..... there's nothing to reverse engineer really, basically some part of this setup can be copied(the dual bulb part) the rest your'e on your own.... to take it apart won't do much good, all you'll see is that it is a dual bulb setup..... you can see that by the wires coming out for the two ccfl's......
    besides, I'd like to have at least one thing in my car that I didn't have to butcher & modify...... this 800 nit 6.4 may just be that one thing......now what I'll have to do to my dash to accept it is another story, this will take some minor modification...... here we go again........
  9. #1089
    Oct 2004
    NY
    hey scouse, you got led's on the brain or what......... didn't youy mean lcd's a few times
  10. #1090
    Mar 2004
    Bristol
    yeah. i am tired. and borede of saying the same thing over and over and over again.
    we need the same rule on here as My Thread!!!
    ie you have to read the whole thread to be allowed to post!
  1. Replies: 13
    Last Post: 12-24-2005, 06:14 PM
  2. Anyone know how to upgrade brightness on LCD?
    By maxcosity in forum LCD/Display
    Last Post: 06-22-2005, 01:09 PM
  3. FS: Nec 10.4" LCD w/ Backlight Inverter
    By SuperMatty in forum Classified Archive
    Last Post: 06-07-2003, 12:21 PM
  4. Replies: 2
    Last Post: 07-16-2002, 09:15 PM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
