Thread: LCD Backlight Upgrade
  1. #1121
    Registered User
    May 2003
    Quote Originally Posted by turbocad6
    & oh yeah.... CHILL DUDE....... theres no one here worth raising your blood pressure over
    EDIT :
  2. #1122
    FLAC alti's Avatar
    NY
    Quote Originally Posted by greenman100
    over on OC forums, I used to get 3-day banned routinely for telling people to search. I am very much of the school of thought that you have to learn on your own.
    That said, I shouldn't have to sort through 1100 posts to get an answer to a simple question.
    educating yourself ::thumbs up::
    posting irrelevant crap no in off topic ::thumbs down::
    having a heart attack over said issue :: 2x thumbs down::
    read the thread.
    this is not the OC forums
    BTW you can search within a thread, that might help you cut down on the time involved.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  3. #1123
    Oct 2004
    NY
    dude, I've had to read through literally hundreds & hundreds of web sites & misc. pages to learn something, that said, the answer to your question is at post 1083 & 1084.... only posted three days ago btw...... & not the first or second time in this thread either, just the latest......
    your question was a simple one, granted....... but it's the same simple question that has been asked over & over & over..... I guess scouse is a little frustrated today....
  4. #1124
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    imagine how I feel, I started this project, i've had to gather all this information.
    I think I wore out
    But I will be updating the first post with more information so you dont have to sift through as many posts
    肚子笑痛了
    S60 Install
  5. #1125
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by jcdillin
    I think I wore out
    you are the man. I'm going to add to the FAQ if that's ok.
  6. #1126
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Updating the first post is a good idea.
  7. #1127
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    why do i feel like homer simpson in that episode where bart shakes up the can int he paint mixer and then when he is in hospital bart remembers the Indiana Jones scene where he slides under the gargae door and homer runs down the road beating his chest in rage?
    I actually got up this morning and thought about writing a brief FAQ of why this wont work and whyt hat wont work. When i get a chance I will post a link in my signature. Then no-one has to search. how is that?
  8. #1128
    Just make sure to put it on a web page too so people can it .
    I have read the entire thread and I want to thank you guys for doing all this research and for putting the results into this thread as you found stuff out for people to read, if they can be arsed to, lazy buggers.
    Don't let the trolls get to you. They aren't worth it.
  9. #1129
    Mar 2004
    Bristol
    Quote Originally Posted by Arathranar
    lol, i wont. I just get a little and go off on a rant while Jerry is quiet and stews over the annoyances!
    there will be an amusingly titles link in my sig soon. but i got to go to work so it may be up by the end of the day.
  10. #1130
    Mar 2005
    ccfl's aren't contantly lit, they flutter at a freq. that isn't normally perceptable to the average human, although there are some that actually have reactions to this fluttering (learned this through research).... if you use multiple ccfl's they must be at the same frequency as each other........ if you use seperate independant inverters they will not be in sync with each other...... the result will be very perceptable & annoying..... that's the whole reason behind multiple ccfl inverters that use an internal closed loop system or multiple inverters that connect to each other in a closed loop design....
    if it was as easy as just hooking up three inverters to three bulbs don't you think others would have done this already? there are a LOT of other factors that determine the final outcome, either right or crap..... color teperature is another factor that I don't see you even mentioned..... if you want to do a sucessful backlight upgrade you need to learn what is involved through research..... if you just want it done for you that's another thing entirely.... if you don't have the time to learn & do all that is necissary then just buy another lcd...... especially if you were satisfied with it as is.... that may be your best option......
    So then do 2/3/4 bulbs wired in series attacked to an inverter that outputs 2/3/4x the starting voltage....
  1. Replies: 13
    Last Post: 12-24-2005, 06:14 PM
  2. Anyone know how to upgrade brightness on LCD?
    By maxcosity in forum LCD/Display
    Last Post: 06-22-2005, 01:09 PM
  3. FS: Nec 10.4" LCD w/ Backlight Inverter
    By SuperMatty in forum Classified Archive
    Last Post: 06-07-2003, 12:21 PM
  4. Replies: 2
    Last Post: 07-16-2002, 09:15 PM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
