Page 12 of 123 FirstFirst ... 234567891011121314151617181920212262112 ... LastLast
Results 111 to 120 of 1222
Thread: LCD Backlight Upgrade
  1. #111
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by chargin
    This is awesome. I hardly use my carpc because the 8" lilliput is (kinda crap)...
    I can hardly see it, I recently got my windows tinted really dark and that made hardly any difference. I was thinking about making a "light shield" that clips on my screen to keep the glare down. This looks awesome. Im up for an 8" also. You mentioned under $100 as the final cost, is that still where we are looking?
    And one simple question.... if its this easy why dont the manufacturers offer cheap, bright lcds???
    Well if the unit survives the heat test and I can find a decent priced inverter, it's still looking under $100 we might be able to make it around $50 but it's still up in the air.
    I really dont know why they dont do something like this, i've asked myself the same question.
    肚子笑痛了
    S60 Install
  2. #112
    May 2003
    Miami, FL
    Quote Originally Posted by momanz
    Wow! I can't wait to try this on my 250nit panasonic panel... What were the specs on the LEDs you got in?
    This test was not preformed using LED's, this was done with CCFL
    but I will be doing a test with 15,000mcd LED's after I finish with the CCFL's
    肚子笑痛了
    S60 Install
  3. #113
    May 2003
    Miami, FL
    also I am sending some sample tubes to scouse, he has a panasonic panel and will be doing the CCFL test on it.
    肚子笑痛了
    S60 Install
  4. #114
    Jul 2004
    duhhhh, poorly worded post on my part. I was thinking of getting a bag of nichia LEDs $85 for a bag of 100 (18000mcd)! I may just wait now to see the outcome of your tests... Good luck and if this works you can count me in for a unit.
  5. #115
    May 2003
    Miami, FL
    85 for a bag of 100? damn, I just paid $30 for a bag of 200 15,000mcd
    肚子笑痛了
    S60 Install
  6. #116
    Jul 2004
    Do you know who is the manufacturer on those? At $30 I may buy a bag just to play with. I'd like to see the spec sheet though... From what I've read Nichia is among the best and they had detailed specifications on their led's brightness and color for all to see.
    EDIT take a look at this spec sheet. 18000mcd is right in the middle of the range that this particular model can produce. If you get some of the V ranked LEDs they are between 22000 & 31000 mcd.
  7. #117
    May 2003
    Miami, FL
    that is interesting, i'll take a look at those further, only reason I went with the 15,000mcd is that Scouse has a guy at his university that already did a backlight upgrade with LED's of the same mcd. But as we had already figured he has a lot of problems getting the light to be even.
    I dont know what the mfg is on my LED's, I will see if I can find the info
    肚子笑痛了
    S60 Install
  8. #118
    Sydney, Australia
    my god.... !
  9. #119
    Jul 2004
    No worries, don't waste too much time on it for now. If you get the CCFL upgrade to work for anywhere between $50-$100 you'll be my hero
  10. #120
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    As you already knew from the begining, I'm definetly in.
    Those pictures are priceless!!
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  1. Replies: 13
    Last Post: 12-24-2005, 05:14 PM
  2. Anyone know how to upgrade brightness on LCD?
    By maxcosity in forum LCD/Display
    Last Post: 06-22-2005, 12:09 PM
  3. FS: Nec 10.4" LCD w/ Backlight Inverter
    By SuperMatty in forum Classified Archive
    Last Post: 06-07-2003, 11:21 AM
  4. Replies: 2
    Last Post: 07-16-2002, 08:15 PM
  5. Replies: 4
    Last Post: 03-16-2002, 01:32 AM
