Page 21 of 123 FirstFirst ... 11121314151617181920212223242526272829303171121 ... LastLast
Results 201 to 210 of 1222
Thread: LCD Backlight Upgrade
  1. #201
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by momanz
    jcdillin, how do you plan on deciding whether or not the unit is thermally... ok??? If you have an smbus or i2c header on your motherboard I may be able to whip up and send you one of these so you can do some testing... It's basically a temperature sensor (1 on chip and 4 remote sensors) that plugs right into the smbus header on your motherboard. You can monitor/record temps using motherboard monitor 5 or speedfan. It would be good to know exactly how hot this thing gets in your dash.
    let me know if you think it would be useful.
    oh, and did I mention that the is soooo coooool
    -momanz
    yes it would be very useful, but as I dont have any motherboards with a i2c or smbus header I wouldnt be able to use it. I think i'm going to just hook one of my ds18s20 temp sensors up with a pic and monitor it with a small charcter LCD
    but thank you very much for the offer
    EDIT:
    actually what temp sensor is that using? because I have been having some troubles with my ds18s20's your board might be more accurate, and I can do i2c with my pic. If you want to make one i'd be happy to give it a try
    肚子笑痛了
    S60 Install
  2. #202
    Low Bitrate McFreak's Avatar
    Mar 2005
    McKinney, TX
    It looks sweet to me but can you describe how it looks in person? Does it look washed out at all, contrast issues, etc? Are you going to have to replace the diffuser?
    CarPC v2: Infiniti G35 Coupe 6MT, DW Housing, IBM R40, GPS, XM, StreetDeck
  3. #203
    May 2003
    Miami, FL
    uhm, looks really bright
    but really it looks very good, it's not washed out that I can tell at all.
    I am not sure about the diffusers, I do have a little bit of uneven light, but I think that is coming from the crappy inverters from china
    肚子笑痛了
    S60 Install
  4. #204
    Mar 2005
    McKinney, TX
    Is this distortion from the jpeg compression/camera issues or is that actually on the screen?
  5. #205
    Jul 2004
    Details on construction and specs are here. I dug up the first one I built, it's ugly (forgot to reverse the pattern) but worked when I first built it. I'll test it out and PM you if it works. the chip I used was the MAX1989.
  6. #206
    May 2003
    Miami, FL
    Quote Originally Posted by McFreak
    yes thats mostly jpeg compression/camera, and some distortion from the touchscreen
    肚子笑痛了
    S60 Install
  7. #207
    May 2003
    Miami, FL
    cool thanks
    肚子笑痛了
    S60 Install
  8. #208
    Mar 2005
    McKinney, TX
    Ok cool, You have to be excited. I think I would have to call in
    "sick" if I had that sitting at home.
  9. #209
    May 2003
    Miami, FL
    it's hard to be at work, while all this stuff on my workbench, I want to find inverters and test more.
    肚子笑痛了
    S60 Install
  10. #210
    Nov 2004
    I was just curious if this adds any depth to the LCD at all or if it's exactly the same width as the original backlight. My LCD is installed without the back casing in my dash and has basically no space to expand. Also, it'd be really cool if someone could rig up a light sensor and mount it to the LCD w/ a DAC or something to control the voltage on the backlight. then you could have a pot tweak to make sure it's the proper brightness adjustment. Now that would be golden. Maybe a good project for my senior design if your tubes stay cool
  1. Replies: 13
    Last Post: 12-24-2005, 06:14 PM
  2. Anyone know how to upgrade brightness on LCD?
    By maxcosity in forum LCD/Display
    Last Post: 06-22-2005, 01:09 PM
  3. FS: Nec 10.4" LCD w/ Backlight Inverter
    By SuperMatty in forum Classified Archive
    Last Post: 06-07-2003, 12:21 PM
  4. Replies: 2
    Last Post: 07-16-2002, 09:15 PM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
