Page 23 of 123 FirstFirst ... 13141516171819202122232425262728293031323373 ... LastLast
Results 221 to 230 of 1222
Thread: LCD Backlight Upgrade
  1. #221
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by Scouse Monkey
    which reminds me. Need to get my tubes stuff sent over and I need to send you some cash.
    Get me your address geezer and i'll send em over! i'm going to send you 2 sets since i'm getting more
    肚子笑痛了
    S60 Install
  2. #222
    May 2003
    Miami, FL
    5. The manual adjustment might be done with 3 buttons. ie one for up, one for down and one to toggle auto on or off. This might be tricky as it will need either a batteyr backup or some kind of non-volatile memory (i have never built anything like that)
    that will be easy as the PIC microcontroller has a small area of memory that can store simple things. such as the previous on/off state and brightness level, and it's NVRAM so it will store it even without power. And even still if that wont work it's very very easy to add a small eeprom that will hold it all without power.
    肚子笑痛了
    S60 Install
  3. #223
    May 2003
    Miami, FL
    faq updated!
    肚子笑痛了
    S60 Install
  4. #224
    Constant Bitrate donde's Avatar
    May 2005
    Texas
    Will you be offering the auto dimming circuit seperate from the entire kit? I would be very interested in purchasing one or two of these and I know several other people that would be too.
    The screen will be dimmed by controlling the amount of voltage to the backlight, correct?
    I know you've already heard this a million times, but great job on the project. It's quite an undertaking and you're really moving quickly on it!
  5. #225
    May 2003
    Miami, FL
    Yes the auto dimming will be a add-on. So you wont need to purchase it if you want to do something yourself.
    Correct.
    Thank you, even if people do say it a million times, makes it all worth while
    肚子笑痛了
    S60 Install
  6. #226
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by donde
    The dimming is done via pwm circuit. You cannot simple reduce the voltage into the inverter as at low voltages the tube will not light properly.
    I think it would be easier for us to just put the plans on the website and let people make thier own circuit.
  7. #227
    May 2003
    Miami, FL
    We could do that
    either way the inverter is going to be controlled via PWM or voltage level, so we really could do almost anything.
    edit: woot! 2500
    肚子笑痛了
    S60 Install
  8. #228
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Quote Originally Posted by jcdillin
    I will be buying one because I think it would benefit me here in AZ. Well done guys! It will be as bright as the Allbrite panels that I sold.
  9. #229
    Feb 2005
    Oklahoma
    just checked out your project site JCD. Looks very promising. What would be a good, reasonable donation amount?
  10. #230
    May 2003
    Miami, FL
    oh at least two to three hundred
    no idea, I appreciate any amount
    肚子笑痛了
    S60 Install
  1. Replies: 13
    Last Post: 12-24-2005, 05:14 PM
  2. Anyone know how to upgrade brightness on LCD?
    By maxcosity in forum LCD/Display
    Last Post: 06-22-2005, 12:09 PM
  3. FS: Nec 10.4" LCD w/ Backlight Inverter
    By SuperMatty in forum Classified Archive
    Last Post: 06-07-2003, 11:21 AM
  4. Replies: 2
    Last Post: 07-16-2002, 08:15 PM
  5. Replies: 4
    Last Post: 03-16-2002, 01:32 AM
