Page 49 of 123 FirstFirst ... 39404142434445464748495051525354555657585999 ... LastLast
Results 481 to 490 of 1222
Thread: LCD Backlight Upgrade
  1. #481
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Just to say I saw JC's mold-job for the first time here and it's awesome!
    Sorry for the hijacking
    Looking good by the way, the project!
  2. #482
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    yeah it is cool. i am damn jealous.
    On another side note: It is amazing the difference Xenarc made between your old screen and the later ones. The onboard inverter is very crude and will have to be disabled when people upgrade by cutting the tracks - like on the lilliput. The panel is slightly different but i suspect the difference is just the moving of a small board on the LCD as the CCFL seems the same. As far as i can see the $150 Xenarc upgrade is a new controller with the separate inverter (or simply putting a new inverter in and killing the original).
  3. #483
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by JC-S60
    I was wondering if you had seen it yet
    Thanks!
    肚子笑痛了
    S60 Install
  4. #484
    May 2003
    Miami, FL
    Quote Originally Posted by Scouse Monkey
    The newer xenarcs seem to have actually redesigned the board from the ground up
    I need to compare the datasheets on the two version to see if they changed the output of the ccfl or they just pumping more energy into it
    but after taking the xenarc LCD apart, I have high hopes that we will be able to get the tubes to fit into there as well.
    肚子笑痛了
    S60 Install
  5. #485
    Mar 2004
    Bristol
    oh god yeah the boards are worlds apart.
    The Gain modules that digitalww sells are similar to the latest xenarc but not the same.
    The newer one uses a lot more surface mount stuff and amkes the old one look like it is out of an 80's TV set.
  6. #486
    Mar 2004
    Bristol
    Oh, i noticed from a screenshot in an ebay auction for the old blue button model that it has autodetect in the OSD so maybe the old ones did have autoswitching - unless it is something to do with auto-on or the resolution.
  7. #487
    May 2003
    Miami, FL
    Quote Originally Posted by antimatter
    How long do you think those stok tubes will last with the upgraded invertor?
    well depending on how much current you run through it, could be cutting the life in half, could be cutting the life down to a couple months, untill I can find the datasheet for the hitachi panel, I wont know
    肚子笑痛了
    S60 Install
  8. #488
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    From dragonBTV:
    "I found a new converter board with no diemming fuction that could be used on the LCD backlight upgrade."
  9. #489
    May 2003
    Miami, FL
    wont work, I already have a inverter like that and it's garbage
    We cannot go without the dimming, because just using my upgraded one is unbearable at night
    肚子笑痛了
    S60 Install
  10. #490
    Nov 2004
    Ok let me tell him this..............
  1. Replies: 13
    Last Post: 12-24-2005, 06:14 PM
  2. Anyone know how to upgrade brightness on LCD?
    By maxcosity in forum LCD/Display
    Last Post: 06-22-2005, 01:09 PM
  3. FS: Nec 10.4" LCD w/ Backlight Inverter
    By SuperMatty in forum Classified Archive
    Last Post: 06-07-2003, 12:21 PM
  4. Replies: 2
    Last Post: 07-16-2002, 09:15 PM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
