Page 10 of 15 FirstFirst 123456789101112131415 LastLast
Results 91 to 100 of 149
Thread: Auto Power On 619 Lilliput - Programing Guide
  1. #91
    Newbie KirMit's Avatar
    Oct 2006
    Moscow, Russia
    It works! It works on Prology PCM-700 Lilu twin monitor!
    Many thanks!
    Mazda6 EU
    Custom CarPC
    Russian Fed.,
    Moscow
  2. #92
    Oct 2006
    I bought my 7inch lil two weeks ago, no tv input, i have the 10 pin connector... I typed in the code, but the unit still doesnt auto power on... And i am horrible at soldering... what can i do?
  3. #93
    Constant Bitrate Perrosky's Avatar
    Feb 2006
    NJ
    I GOT THE 629 I GET IT FROM MP3CAR I DID STEP BY STEP WHAT THE INSTRUCTION SAYS AND EVERYTHING WORK GOOD BUT WHEN I DISCONECT THE MONITOR FROM THE CIGARETE LIGHTER AND PLUG IT IN AGAIN THE MONITOR DON'T POWER UP JUST STAND BY, CAN IT BE BECAUSE I DON'T GOT THE USB CABLE CONECTED TO THE PC.
    NOTE: I still don't install the pc on my car, I was testing with my laptop, and conecting the lilli to the cigarete lighter as power source.
    One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
  4. #94
    Nov 2006
    Won't work for me either
    Just bought 619GL-70NP/C/T and I tried all the previous tricks and nothing works . Anybody who bought same recently get it to work? Thanks.
    I can't get the menu to come up.
  5. #95
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by synonomous18 View Post
    I am in the same boat as you. I try every tricks stated in the forum and some stupid thing from my own. None of the tricks work.
    You can try jaming one of the button to enable auto on, but this method leaving the buttons unoperative. However, you can control with the remote.
    If you don't know what I mean, try this. Press and hold any of the button (power prefer) and plugin power to the monitor, it should turn on => auto on. This is not a trick of my own but been floating around for a while. I found that it is okay to do it this way instead of RC mod (aka Coyotte auto on).
    In the end, I just prefer not having auto on because there is time I don't want the monitor on by itself such as moving the car in and out of the lot for a wash or short trip to the liquor. If I can get it thru the code, it's perfect. Otherwise, I just jam a piece of paper on the power button and I have auto on .
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  6. #96
    Mar 2006
    did you try the trick i did with the remote battery?
    auto on for EBY701 lilliput...
    For some reason it only works if I do what I did in that thread. Otherwise I can never get the admin menu and that was after at least 200 tries.
    Cars:
    2001 Lexus es300 carpc Complete!Lexus es300 thread
    CarPC: Hp laptop, Lilliput 7'' ts, ig3, bluedevil skin, hauppage tv tuner, bu-353, griffin powermate, backup camera, ps2, headrest monitors, nightvision camera.
    2006 Lexus es330 next project.
  7. #97
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by spiike View Post
    Been there, done that.
  8. #98
    Feb 2007
    I have the lilliput 619
    i have tried this code for quite a while and finally got a result.
    For me, i needed to removed the power source from the screen for 15 seconds, plug it back in, turn it on with the button, wait for the blue lights to go out, and then enter the code. this worked great
    before that i tried it a ton of other ways and nothing would come up on the screen. Hope this helps someone
    also, i wanted the screen to automatically come on when power was applied, i ended up having to us 2 as the power option so it would use the last setting which was on. With 1 selected it would start in standby mode.
    Im happy it worked out!!
    thanks guys
  9. #99
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    someone should update the first post of this thread with the additional info that's been gathered in these 7 pages. I went through this last night with my new transflective from mp3car.com and the only way I got it to work was with: remove battery from remote trick, otherwise factory menu would never come up, and using 2 instead of 1 for the code for the power setting.
  10. #100
    Banned
    Feb 2007
    619 is best on in Lilliput
  1. Replies: 32
    Last Post: 05-05-2005, 11:49 AM
  2. HELP! lilliput wont power up
    By fenderbender in forum LCD/Display
    Last Post: 03-02-2005, 04:35 AM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. Power for the lilliput
    By zmann in forum LCD/Display
    Last Post: 12-04-2004, 01:57 PM
  5. ATX auto power on
    By jumpoint in forum General Hardware Discussion
    Last Post: 01-25-2000, 03:56 AM
