Page 12 of 15 FirstFirst ... 23456789101112131415 LastLast
Results 111 to 120 of 149
Thread: Auto Power On 619 Lilliput - Programing Guide
  1. #111
    Mar 2004
    I just did this with my new 8" 889GL. By default it was 1270100 and would start up in power off mode when power was applied. Using 0970200 worked for me. It didn't save the settings at first, I just fiddled around with it few times and eventually it saved the setting and is now working great.
  2. #112
    Mar 2005
    Sweden/Vaxjo
    nice guide, much better then having to rip apart the screen and start soldering!
    I have a "noname" screen but the circuit board looks identical to the 629 lilli one and when I enter 588998 I get the --- -- -- at once, I tried the code on the first page but that didn't do anything...
    I've read though all the pages and it seems that there is a number of codes that might work but I'm just worried about trying them out... is it safe to just try the different numbers or can I screw up the screen in any way?
    Swedish site for CarPC's
    http://www.bilpc.info
  3. #113
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    Quote Originally Posted by diosagain View Post
    I actually figured it out. You have to press the menu button on the actually screen buttons and then go down to power mode and using the other buttons on the screen toggle to the number 2 for power mode. It works great. You can also turn on other video sources such as TV and turn off certain things as well. I hope this helps anyone that was stuck the same way I was.
    Quote Originally Posted by jjnit View Post
    Oh YEAH!!!!! Thanks diosagain - I've been trying to get this for about 2 months now!
    Hit the 588998 combo from the remote, then the menu button on the screen itself, and then you can use the < > buttons to scroll up and down, and Vol + - buttons to change values - all kinds of things I hadn;t seen before.
    Just to note that it worked on my new 889GL (8" widescreen bought at mp3car.com).
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
  4. #114
    Mar 2007
    so it only auto powers on when it detects power?
    Is there any way to get a lilliput to power on when it detects VGA signal instead? Like a PC monitor?
    sorry if this is dumb question, I haven't gotten a lilliput yet.
  5. #115
    Nov 2006
    Sao Paulo, Brazil
    Quote Originally Posted by Snortonnorton View Post
    In my lilliput, when there is no VGA signal you get a signal lost (dont recall the exact message) and in very few seconds it enters in standby.
    When VGA signal reappears it wakes up.
    Its like any other LCD PC monitor.
    The autopower thing is for energy, when you plug the energy cable it will automatically turn on.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  6. #116
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by vladcarpc View Post
    Be very careful of just having the screen in standby, if left like this it will drain your battery.
  7. #117
    Nov 2006
    Sao Paulo, Brazil
    Quote Originally Posted by Enforcer View Post
    I see. I plan to attach it to the M2-ATX, so when CarPC hibernates screen is powered off.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  8. #118
  9. #119
    Variable Bitrate tigergibb's Avatar
    Nov 2006
    Snellville, GA
    Didn't originally work for me, had to play around with it a bit, but now works great! Thank you!
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
  10. #120
    May 2005
    Here's my issue I am having at the moment. Everytime I input the 588998 code, it just pops up a menu that says English or a bunch of other languages, no "--- - - - -". How do I pull up this menu? I even did a reset on the monitor and I am still not getting this.
  1. A different way to Auto Power On your lilliput
    By intense in forum LCD/Display
    Last Post: 05-05-2005, 11:49 AM
  2. HELP! lilliput wont power up
    By fenderbender in forum LCD/Display
    Last Post: 03-02-2005, 04:35 AM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. Power for the lilliput
    By zmann in forum LCD/Display
    Last Post: 12-04-2004, 01:57 PM
  5. ATX auto power on
    By jumpoint in forum General Hardware Discussion
    Last Post: 01-25-2000, 03:56 AM
