for those of you who are having trouble. Try turn on your carputer and the screen is bright enough to see.
Tried all the methods with my monitor and none worked. The monitor its a older model, bought april / 2004.
Sorry I cant report the model number because to do so I would have to remove it from the dash.
It has the 9 pin connector.
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status --> Lilliput Installed (not indash yet..)
BraveCar 2.5
uh?
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
woooooooooohoooooooo worked on my lilliput ill get u guys the model number tommrow its like 1 40 am im sittin in my garage in my car like an idiot but wooohooo this is pimp! thanks !!!!!!
Hi everyone! I only registered to submit my model and inform you that the code is working. :-) I've been lurking for a month or so and EVERYTHING can be found by smart searching. For a month, every question I had has been previously answered by someone. Great community, people. Although hard to keep track of, there are hundreds of posts every day....
About the coding: worked like a charm from the first try. My monitor looks like this:
http://www.mp3car.com/store/images/v...lil7t_logo.jpg
...model is 619GL-70NP/C/T, native resolution is 800x480 and it's serial number is 61980705B0047.
Hint to everyone having trouble with entering code: try playing with the main menu (press MENU button on the remote) and navigating through it (up/down arrows, MENU is confirmation of selection) to get a sense of how long to press the button and where to aim the remote beam.
the codes work just fine on mine.... model is a 629GL-70P/C/T. What Armen said about the factory mode on the menu also happens on mine. As he said, just disconnect the power and reconnect and then you can get back into the factory setup.
my model number is 619GL-70NP/C/T and it worked fine for me!!!
sweet mine worked too thanks Anointed. I've got the same one as Gore-. It seemed for me however that the input screen was missing a dash....so I just typed in 127010 and then I got the menu header/footer that digitalww was talking about....at this point auto-on was working.
PC Components:
My work log
Jippy
The codes worked also for mine Lilliput 7" LCD 619GL-70NP/T
thanks for sharing this wonderfull option with us!
Do you think it culd work on the Linitx screen? It has the same screen as the Lilli, even the inverter is Hitachi.
