Mega, can you post the exact steps and times on pressing buttons etc ? Hope it helps some ppl out, but I think it's desperate for those who can't get it working.
Thanks a lot.
thank you Anointed!!
I can confirm that the codes work with my old 7" lilliput (grey version) with a 10pin vga connector.
model# 619GL - 70NP/C/T
Lilliput 7" TS / VIA EPIA M10000 / 512 MB DDR RAM / 40 GB 5400rmp 2.5" HDD / Samsung Slimline DVD-ROM / M1-ATX 90w PSU / Kenwood KDC-W5031 / Tranquil T3 Case / GPS Mouse
INSTALL COMPLETE :)
http://megatr0n.blogspot.com/
Thanks a lot.
Car : Hyundai Tucson
Carpc :
Lilliput 7" touchscreen indash 90% done
PSU : M2-ATX
Epia M10K /512DDR/80GB Maxtor
Software : Windows XP Pro 100% done
RR with DigitalFX skin
In car : 80% done
Sure no problem.
I booted up my desktop and switched on my lilliput
Waited for windows to load up
Pressed in the following code using the remote 588998 (waited about 1 second between each keypress)
As you can see in my above posted picture - the factory setting screen comes up
Then I entered the following code 0970110
Pressed 5 on the remote to save the settings (you can press any button to save, i think)
Hope that helps!
INSTALL COMPLETE :)
Thanks Mega, but doesn't help me either. Def. giving upnow. Going to do the Coyote-mod.Originally Posted by mega
Carpc :
PSU : M2-ATX
In car : 80% done
Nothing wrong with thatOriginally Posted by gyro
I am still using it myself, despite a working factory setup menu.
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
I've got an 8" lilliput, anyone with this screen did the coyote mod?
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
This is the monitor I have, and I can't get no factory setup to come upI'm losing hope
I'd go for the Coyote mod if I were you. If you're not good in soldering yourself, ask someone who is to do the job. I modded mine and it works like a charm.
Carpc :
PSU : M2-ATX
In car : 80% done
Damn! It doesnt work for me no matter what i try! I feel so ripped off.
I would do the Coyote mod, but my soldering iron's tip is too big and the pins on the LCD are too tiny. And i dont have time....college sucks, work sucks, women suck (litterally)
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
