Results 1 to 10 of 11
Thread: ok to put cardboard behind my lilli board?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    I put my lilli in a custom case, however the case is too deep and i need to put something behind the board to prop it up. Is cardboard ok? Its vented and the case has plenty of room for air flow.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    to be safe i would try to fit the stock lilli piece on it trim it up and stuff its way better that way
    Woodbridge, VA
    Blog Entries
    32
    well thats hte prob.. i bought my lilli used and without any brackets or casing. I installed it in my old TFT screen case which works well cause it matches my interior better.
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    I'd use peices of stiff foam, myself.
    Aug 2004
    Snellville, GA
    But doesn't foam melt?
    Oct 2004
    Massachusetts
    the only thing you have to be careful of is HEAT. The main board of the Lilli has an element (rectangular in shape) that gets VERY hot.
    Is it enough to burn your finger? OH YEAH, as I've found out.
    Is it enought to set paper on fire (imagine using the screen for a few hours and the heat building up) or melt foam? Maybe... it would be best to go with a piece of plastic (you should be able to pick up some thin plastic from any hobby supply store)
    Epia MII 10000 512MB RAM - 60 GB 2.5" Hard Drive -Opus 90 - Lilliput 7" Touchscreen - Panasonic 8123 Slotload DVD burner - PCMCIA USB2.0 Card - Rikaline 6010 GPS - PS2 Micro Keyboard
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    I use a piece of hard plastic (similar in size and material to the original case) to mount the board in, then I have a piece of foam that pushes against the back of it to keep it flush.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by shamyday
    you got burned by high voltage, not heat from the transformer, I have 2 lilliputs and that transformer doesnt get hot.
    肚子笑痛了
    S60 Install
    Dec 2004
    why not just buy a new lilliput housing mp3car store shud have it or www.digitalww.com
    Maximum Bitrate Cartunes's Avatar
    May 2004
    I've use cardboard, and it works just fine
    1992 z71 Chevy
  1. ASRock motherboard (SIS 741 chipset) any good?
    By ericthebikeman in forum General Hardware Discussion
    Last Post: 08-03-2004, 01:08 AM
  2. Replies: 0
    Last Post: 07-20-2004, 02:32 PM
  3. Realy board software
    By withoutcomp1 in forum Software & Software Development
    Last Post: 05-20-2004, 02:15 AM
  4. FS: VIA EPIA MINI-ITX M9000 Board
    By Elmezie in forum Classified Archive
    Last Post: 05-16-2004, 04:01 PM
  5. Can an AT PS power an ATX board?
    By selfentitled in forum Power Supplies
    Last Post: 07-29-2002, 04:46 PM
