Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Another 'unknown device' lilli touchscreen problem
  1. #11
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I had this problem and was going to replace my controller then on saturday the device just started working again. I took the monitor out of my car to do the IR receiver mod and it just started working. Of course my ribbon cable crapped out the same day but hell you cant have it all right.
  2. #12
    Variable Bitrate spyhunter's Avatar
    Jul 2002
    central jersey
    I have had this problem a few times in the past. I currently am running lilliput gen 1 in the tm housing that Armen sells. I installed it myself and had some issues with it, sent to to Armen after roughly a years worth of use with no problems (got the problem then). Armen reinstalled it and fixed everything up. A few months down the road, i got the same problem again.
    From what i've determined, it is mostly caused by wiring issues. Inside the indash housing, the wires from the lilly to the back would get caught on the latch everynow and then. Eventually it ate through the wires, video signal and touch. After repairing it, removing the latch and spring, I haven't had any problems in a few months now.
    Alex
    90 300zx twinturbo conversion
    Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
  1. Lilliput Touchscreen problem
    By DookieGraphics in forum LCD/Display
    Last Post: 03-24-2005, 03:33 AM
  2. Lilliput touchscreen problem
    By samc in forum Input Devices
    Last Post: 05-09-2004, 12:12 PM
  3. Touchscreen Issue
    By li_runer in forum Input Devices
    Last Post: 05-06-2004, 11:05 PM
  4. Touchscreen, problem
    By Sh0cker in forum Input Devices
    Last Post: 02-03-2004, 07:50 PM
  5. Touchscreen problem
    By Crav4Speed in forum Input Devices
    Last Post: 01-08-2004, 01:33 AM
