bump
Like the title says, sometimes when I resume from Hibernation the image on the screen isn't displayed ... I have to power off then power back on. Usually there is a few white lines at the very top of the screen, but nothing else. Sometimes (not usually) the screen displays everything perfectly when I resume from Hibernation. I have a feeling it's a software thing .. any ideas?
-Brad
83 mp320i
99 mp323i
_________
7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
bump
-Brad
83 mp320i
99 mp323i
_________
Many Lilliputs (including mine) have a problem when resolution changes are made quickly. When you're coming out of hibernation or a cold boot the BIOS and Windows startup screens usually run rather low res. (like 640x480), then once your Windows video driver is loaded the res. changes rather quickly to whatever your desktop res. is set to. When I have this problem I usually have to turn the Lilliput off and back on. One work around would be to delay powering up the Lillput until the Windows video driver is loaded.
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
Yes, to get around this problem I just built the circuit outlined in this post. It kept me from getting the over range and jurrasic park logo problems.
http://www.mp3car.com/vbulletin/show...4&postcount=15
肚子笑痛了
S60 Install
