So you couldn't get the VGA input to the monitor working with your desktop computer either?
Does the Lilliput have a source select button?
I newly recived my Lilliput 8 inch touchscreen. When I plugged the VGA-connector into my mini-itx mainboard to power up the system I could not get a picture. I tried the Video-Output on my mainboard and it worked with a S-VHS cable. The imagequality, resonably enough, was quite poor. Are there any spesific settings required? I tested the screen on my desktopcomputer but got the same results. I've updated my BIOS and Displaydrivers.
If any of you guys got a bright ideea of what my problem might be i would be thankfull for your respons.
BTW: I know my english is'nt perfect, not used to your fine international forums
If you got any additional questions, please ask
Kristoffer from Norway
Yes.. and I managed to get that one right![]()
Have you wait until windows boot up completely? I have the same combination as you and I cant see anything on the screen until win has finished the boot.
Via Epia M1000
512MB RAM
120MB IBM Hard drive
Netgear MA111
Lilliput 8" Touchscreen
http://www.clarre.com/carcomputer.htm
I've tried that.. but still.. nothing happens :|
Could you give me a hint on your settings?
What kind of settings do you have in your BIOS? (PAL/NTSC, Screen Resolution etc)
What kind of settings do you have in windows? ( Hz, Screenresolution etc)
Any additional features?
When you start your computer do you get a picture automaticly (asuming you pushed the screens powerbutton and windows is finished logging in) or do you have to choose input on your screen?
If you unplug your screen do you have to restart the computer to get a picture?
Thank you for your respons..
In the BIOS I have it set to lcd, don't remember the resolution, and I think it's set to PAL. My windows settings are 60Hz and 800x600. I can unplug the screen and plug it in again and get picture directly. The screen always start in VGA mode.
Via Epia M1000
512MB RAM
Netgear MA111
BTW try to reset your BIOS, because what I can remember I saw the boot up screen the first time I start my new screen. Then I go into the BIOS and change my settings. I read somwhere in this forum that it should be set to LCD but after that I can't get in to the BIOS. I shall try to reset mine when I can get my self to remove the computer because now I have the PC in my glowebox so I can't do it without to remowe the PC first. It's a little annoying that I can't get to the BIOS.
Via Epia M1000
512MB RAM
Netgear MA111
I have M10k and 8" lilliput. when the BIOS is set to LCD, the lilliput would NOT display anything... I have to use CRT+LCD. 800x600.
BIOS should be set to CRT+TV if you want to use the VGA port and the S-Video or composite ports together, I believe LCD is for the LVDS interface on the board.
Thank you for your respons. I think I got a faulty screen and I'm sending it back. I have never got a Post-screen or anything on my screen. And from what I understand, if your settings are in the range of your screen and you set your screensettings to CRT+LCD or just CRT i should have got a picture.
Off-topic: Is there a easy way to hook up booth my Lilliput via the VGA and my projector via the VGA?
Thank you for all your usefull info.
