maybe it's scared of you if you are a dodgy russian mafia geezer!
sounds like interference. do you ahve any power cables next to the VGA cable?
How have you connected your screen to get power?
does the shaking get worse when you rev the engine?
I just buy a lcd tview monitor and when i hook it up to the pc the picture is shaking.
does any one know why is that ?![]()
just hold it steady.
Is this where the witty comment goes?97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
yes i connected it to the power but it still has a lines runing when i turn on the pc
Just steal another one![]()
just kidding...
Does your screen have a RCA input? If yes turn your PC OFF, turn your monitor ON, plug in an RCA source, like a DigiCam TV-Out or something...if the picture is not "shaky", meaning interfearance, then its your PC. Try to isolate and ground properly. If its still "shaky" then its probably the power connection of your monitor. Again look at the gound and power cables neerby. If everything else fails, try it at home with your home PC. If its still "shaky"...well steel another one, your are the mafia for gods sake!(just send it for repair)
or turn your refresh rate up, you might have it at 60hz you need to move it up to 70 to 75hz
and make sure you do a auto adjust
肚子笑痛了
S60 Install
Ill do it as soon as i come home from virginia. witch will be in 2 days thanks alot![]()
Russian Mafia:
1. MAke sure everything that is (-) Gound is securely, tightly attached to the metal of the car (the metal of the car should be scratched till is shines!)
That should do some good.
2. If problem persists Then check (+) positive wire should come straight from the battery and should be more than 10G.
tell us the results, ciao
DICE
DICE Los Angeles
