Results 1 to 5 of 5
Thread: Xenarc Touchscreen Tx Rx wiring help
    May 2005
    http://www.digitalww.com/images/VGAM_assembeled3.JPG
    Guys,
    I am new to this board and want to say hi to everyone
    Anyhow, back on topic.
    This girl is in need of some desperate help.
    I have a Gain/Xenarc 7 touchscreen (serial) monitor.
    Anyhow, my touchscreen is acting up. I need your help.
    Based on the picture provided at the following url:
    can you tell me which color cable is the SERIAL Tx and SERIAL Rx?
    Thanx
    Hope to hear from you soon
    NOTE: My VGA connector on the PCB board is broken. I can't solder so I am thinking about hot wiring my serial cable directly to the touchscreen controller itself. Clever huh?
    May 2005
    BUMP
    Anyone?
    All I want to know is what wire is for the serial Tx and Rx for my touchscreen. I thought it was the brown and green wire but I guess I was wrong. i don't want to fry my board. All I know is that there are four wires that makes up the toushscreen cable.
    One is for power, ground, Tx, and Rx. that is all I know. help if you can
    May 2005
    bump. come on guys. i need your help. thanx
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    why not just power up the monitor and find 5v and gnd going to the controller, the the other two will be TX and RX then if it doesnt work you can just swap them around
    肚子笑痛了
    S60 Install
    May 2005
    bump anyone?
  1. Replies: 1
    Last Post: 11-08-2006, 06:20 PM
  2. Wiring Xenarc to wiring harness?
    By deftones8769 in forum Power Supplies
    Last Post: 04-10-2005, 10:07 AM
  3. Xenarc 800TSV 8" VGA Monitor with touchscreen and video inputs
    By therussman2002 in forum Classified Archive
    Last Post: 03-03-2005, 09:42 AM
  4. Xenarc Touchscreen powerfeed. Converting to selfpowered?
    By live2themaxuk in forum LCD/Display
    Last Post: 01-08-2005, 12:08 PM
  5. Xenarc Touchscreen & Linux
    By cjastram in forum LCD/Display
    Last Post: 10-06-2004, 09:43 PM
