Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: prob with sharpe of dash and dww-700m
    Newbie patz's Avatar
    May 2005
    Canada
    prob with sharp of dash and dww-700m
    i got prob with dww-700m, because of the sharp of my dash
    check the picture
    black is the best position (for me)
    green is default position (after opening)
    but when I open it, screen motor stop moving (because of dash).. but will stay here (red)
    (so I use button for move screen to black position)
    but when I close screen and open it back, it goes at red position
    so, I think the screen does not resume last position when it's stopped during opening ?!
    I don't think motor will work for a long time.. (open, jammed because of dash, close, [...] every day)
    somebody get this prob too ?
    idea how to get screen go to black position when opening ?
    sorry for bad english
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    there will be a contact switch on the side rails inside the unit defining in which position motor should stop ejecting screen (i.e. green position on you picture). chances are you can adjust the position by relocating that switch somehow.
    Constant Bitrate takissd's Avatar
    May 2004
    San Diego, CA
    hot exactly the same problem as patz. i am just leaving it to see what i am gonna do, though i dont think there will be any problems
    -VIA EPIA M10000/512MB/40GB HD
    -DWW motorized 7'
    -BU 303 GPS w/iGuidance/ CF
    -Opus90w
    -Belkin Bluetooth
    -Pioneer HU
    [||||||||||] 95% done
    Constant Bitrate HoSS's Avatar
    Dec 2004
    Quote Originally Posted by LagunaICE
    No, it works with an encoder counting the motor rotations.
    Beleive me, i understand mine well after the hours i put in to get it working.
    May 2005
    Canada
    Quote Originally Posted by HoSS
    do you have a workaround..
    each time I eject my screen.. i think it's the last time it will be ejected
    Constant Bitrate John_Duh's Avatar
    Feb 2005
    Belgium
    mine is very irratic about it... sometimes it will hit the dash, and sometimes it will just stop in the last position.
    Does this thing work with some sort of volatile memory ? (thinking of this since i don't leave it powered when the computer is down)
    '02 Toyota Celica TS
    Carputer progress : [#######---]
    Currently working on : software ...
    Parts : IBM thinkpad X60 wired up in the booth (T7200 - 1.5Gb Ram - 320GB HD)
    Parts needed: USB wifi dongle (with external antenna)
    Feb 2005
    Belgium
    *bump*
    Anybody got some input on this, i wouldn't want to fry my screen-motor
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    I find that the screen returns to the exact same spot as when it was retracted. Does your go to a different position.
    Are you guys keeping the power wires powered, and just switching the accessory wire to get the unit in and out, or are you removing power completely from the unit when you turn the car off?
    Michael
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    tagging along to learn about this as I think this might be an issue for my next install
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    FS = MTSVO motorised in dash screen pm me for details
    Feb 2005
    Belgium
    for the moment i've got it hooked up to the PSU, i.e. not constantly powered. (i'm going to resolder that over weekend)
    Normally, when i open my screen it either hits the dash or stops one position further than my last opening position. I would say it's about 25-75% split between what it chooses, but so far i haven't been able to figure out a logic behind it.
