Results 1 to 7 of 7
Thread: Lilliput Lcd fuse blown help!!!!
    Apr 2005
    Miami
    Exclamation Lilliput Lcd fuse blown help!!!!
    i have a lilliput lcd 7" and the fuse is blown it's not the ribbon cable. i check that. no power. the fuse says a symbol of a triangle with a "T" inside witha a lil line on top of the T. also it says KOAC 1A.. can anyone tell me what these things mean?? i need to replace it. i don't know what kind of fuse it is. i went to digikey. i think it a SMD fuse. but is it fast or slow acting. i need to know exactly what fuse to buy
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Looks like your straight out of luck.
    I'll take your broken worthless screen of your hands for 50 bucks
    Just kidden Try Armen at digitalWW
    Constant Bitrate studmonk3y's Avatar
    Feb 2004
    Honolulu, HI
    I thought I remember reading somewhere on this forum that someone else had this problem and soldered in a regular sized fuse. Searched for you and found it. Hope this works for you.
    So it finally happened to me.
    Apr 2005
    Miami
    but what type of fuse should i get. is there anyone that knows. i need exactly which one
    Jan 2004
    California
    what he is saying is that you can replace it with any sort of 1 amp fuse. even one that doesnt necesarily fit. Shoot you can just solder a wire across it to get it to power up again although i don't recomend that becasue you are bypassing the fuse protection.
    Sorry i don't have a part number but do a little a research on google. And call armen
    Apr 2005
    Miami
    im no good in searching for things like that. i did that before going on here. who armen? i went to the website but nothing on armen
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    you need to actually call or e-mail armen to get a fuse from him
    肚子笑痛了
    S60 Install
  1. FS: 7" Lilliput LCD + TOUCHSCREEN
    By calvincbr in forum Classified Archive
    Last Post: 04-09-2005, 04:36 AM
  2. FS 7" Lilliput LCD panel only
    By mi800 in forum Classified Archive
    Last Post: 03-27-2005, 10:25 PM
  3. Replies: 6
    Last Post: 06-22-2004, 09:06 AM
  4. FS/FT Lilliput VGA Touchscreen LCD
    By joebdii in forum Classified Archive
    Last Post: 06-19-2004, 03:56 PM
  5. Lilliput LCD monitors
    By 001 in forum LCD/Display
    Last Post: 10-27-2003, 03:46 PM
