Page 11 of 14 FirstFirst ... 234567891011121314 LastLast
Results 101 to 110 of 131
Thread: Lilliput Programming Guide, More Reset Codes
  1. #101
    Newbie legendcoupe's Avatar
    Jul 2007
    Sweden/Norway
    I can confirm this solution with a new 629GL-70NP from mp3car store.
    The codes in the beginning doesn't match this new model and the procedure has to be the one mox described earlier in this thread.
    mox procedure:
    1) Completely disconnect the 12V power cord from your lilliput
    2) Reconnect power and turn the lilli on by pressing the power button (on the screen)
    3) Now, while in VGA-mode, enter the numbers (588998) directly, i.e. without first pressing any other keys or activating any menus or whatever.
    now to set auto power on with 629GL-70NP:
    My default values were 129 0 1 1 0
    Changed the 5th number (thanks wasyed) to get 129 0 2 1 0 and then pressed a random number on RC to store the new setting.
    Works like a charm!
  2. #102
    Newbie shaggy_5420's Avatar
    Feb 2006
    Near St. Louis, MO
    Hey thanks to all you guys paving the way for us newBs. I ordered my 629 from DigitalWW and it is scheduled to arrive tomorrow and after I test it for functionality, I will be trying the factory settings for auto power on.
    On a side note, does anyone with a 629 know if it will auto switch to the RCA or video 1 (I was going to use it for my backup camera) I remember reading that it specifically does auto-switch but as I am reading this thread and the other one (Props Coyote!!!) and it seems that there is a model with a remote wire just for the auto switch. Can this be accomplished through the factory settings mode? or only with the remote wire?
    Thanks in advance!
    So Far: MII10k, 1GB PC3200, 100GB HD, M2-ATX PS, Ampie Case, Panasonic CD-RW DVD-ROM. Orinoco Gold, Lilliput 629, WiFi, TV/FM, and Amateur Radio Antennas, BU-353
    NEED TO BUY: AMPS MINE WERE STOLEN!
    NEED TO INSTALL...EVERYTHING, AGAIN
  3. #103
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Ummm, Shaggy..........
    I think you need to read the first post in the thread again..........
    Leonardo Da Vinci
  4. #104
    Feb 2006
    Near St. Louis, MO
    I see, I didn't see that on my first time through the thread, I actually followed a link from... I believe that it was coyotes thread. Has there been a discussion on how to setup a way to auto switch from VGA to AV1? it's not that big of a deal to press a button, but the functionality would be nice. I am curious to see what revision my 629 is, after reading the thread a second time I have noticed that there are quite a few people who have the same model monitor but (as with most electronics) they have different boards/revisions.
  5. #105
    Constant Bitrate agniusm's Avatar
    Oct 2006
    Lisburn
    This lilliput in-dash screen accepts that code 588998
    There is graphical menu istead of entering numbers manualy. I could not make the lilli open automaticaly when power is supplyed.
  6. #106
    Jul 2006
    new york
    Lilliput 8" Widescreen (16:9) VGA Touchscreen 889GL, is there anyway to have this screen switch from vga to av1 automatically? i use 588998 to set it to do auto trun on which works great.
  7. #107
    Feb 2007
    Works for me!
    I have an 8" Lilliput 809GL-80NP/C/T
    Tapped in 588998 in VGA mode
    Factory settings --------- was then displayed
    Using the numerals I typed in
    0010101
    Then pressed any key (3)
    **** down the PC, Pressed the on button and the Lilliput booted up. Im so happy!
    This completely puts my faith in my CarPC as I have had a broken ribbon cable for ages and couldnt fix it.
    This code means I no longer need the ribbon cable!
    Thanks guys, alot more helpful then the UK forum!
  8. #108
    Low Bitrate dLockers's Avatar
    Jul 2007
    How do i tell the model of my monitor? Cause I chopped it up about 6 months ago and fabricated it into my dash, have had to run an extension for the IR port.
    For some reason, none of the codes posted thus far bring up the menu on it.
  9. #109
    Newbie daithan_3's Avatar
    Feb 2008
    Thumbs up help for lilliput 858GL-80TV
    i've one 858GL-80TV it's beautiful product but now the tv function is lose,
    when i push a/v button is possible enter only in av1 - av2 - Svideo - vga.
    the tv option is skip.
    i've try to reset with "manual" procedure, but no changes the status.
    thanks
  10. #110
    Feb 2008
    Smile
    Dear Sirs,
    I bought a LCD Monitor/TV type 858GL-80TV
    When the Monitor is on one the key "A/V " is out of order because I don't succed in returning in TV mode if I press "A/V"
    Could you please tell me the right instruction to resolve this?
    thanks to much
  1. Auto Power On 619 Lilliput - Programing Guide
    By Anointed in forum LCD/Display
    Last Post: 10-23-2010, 05:26 AM
  2. Replies: 118
    Last Post: 10-22-2010, 03:05 PM
  3. Lilliput problem - Gain settings seem to reset
    By Cheater2k in forum LCD/Display
    Last Post: 09-29-2004, 05:26 PM
  4. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 08:41 PM
  5. Replies: 5
    Last Post: 04-01-2004, 04:37 AM
