Page 13 of 14 FirstFirst ... 34567891011121314 LastLast
Results 121 to 130 of 131
Thread: Lilliput Programming Guide, More Reset Codes
  1. #121
    Feb 2007
    Lilliput 8" Widescreen (16:9) VGA Touchscreen
    Can someone help me with my monitor. A little while back I was trying to do the auto on mod using the codes. I think I may have entered the wrong code because my monitor now will only display in 640x480 . Is think this is because I entered the wrong code. I there a code that will revert my monitor back to the factory settings?
    thanks in advance for any help
  2. #122
    Feb 2009
    i have an eby-701...is there any way in the advanced menu to make it so the side buttons stay illuminated instead of turning off after 10 secs
    2004 NHBP EM2
    K24 Frankenstein Swap
    212hp/180TQ
  3. #123
    Nov 2007
    Quote Originally Posted by Spawn12336 View Post
    I just recently got the same monitor. Like most of the previous posts said, once you have entered the 588998 on the remote, you use the hard buttons on the side of the monitor to navigate the menu. You select you language, then press menu to move on to the other options. Worked perfectly for me.
    worked for me on EBY 701.. thanks
  4. #124
    Apr 2009
    help me
    Hi. I'm italian.
    i've read some of this thread.
    i've write the code and i switch on the TV option.
    Now i don't see nothing on my lilliput and i don't know what to do to come back.
    Sorry for my English.
  5. #125
    Oct 2009
    Lilliput 669GL what should i do? it's not working for me! I was requested to follow these steps : steps:
    1. under AV or VGA mode, press "POWER" 4-5seconds, then will show the factory's menu;
    2. from the menu (can be operated from remote control, or by 669gl buttons) choose the factory mode:
    page 3 (first page is for language, second is for functions, third page is for setting);
    3. choose the "power mode" change "0" into "2"
    4.press MENU to confirm, then exit ,finish it.
    but no cure
    Any possible ways?? I'm trying it in the PC channel of the screen! That's VGA, isnt it?
  6. #126
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Quote Originally Posted by 307pavlos View Post
    but no cure
    Have you read Chris's guide on accessing the hidden menu for the 669? Here you go:
    http://www.mp3car.com/vbulletin/lcd-...put-669gl.html
    Make sure you actually have a PC connected and sending video to the screen.
  7. #127
    Oct 2009
    Oh thank you kegobeer!!! much appreciated! I tried using the remote control but as chris' guide mentioned, you must use the button POWER, not the remote control! I'll check it in the afternoon when i go home!
  8. #128
    Nov 2010
    Panama City Beach
    No problem.
  9. #129
    Nov 2010
    Is there a way to do this without a remote? I bought my screen used and it never came with one.
  10. #130
    Nov 2010
    Is there a way to do this programming mod without a remote? I got a gently used EBY701, but it didn't come with a remote.
  1. Auto Power On 619 Lilliput - Programing Guide
    By Anointed in forum LCD/Display
    Last Post: 10-23-2010, 06:26 AM
  2. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  3. Lilliput problem - Gain settings seem to reset
    By Cheater2k in forum LCD/Display
    Last Post: 09-29-2004, 06:26 PM
  4. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
