Only the code![]()
so if you input the code, do you have to do the auto power on mod of the circuit board? or can u just set it with the code without doing that?
awesome! way easier than doing all that soldering.
We are on the same boat. My LCD is about that "new" tooOriginally Posted by Cheater2k
. 619GL-70NP/T
I has try direct bunching in the code.
VGA mode reset then bunching in the code.
Bunching in the code then push MENU
VGA reset, Enter Code, Push Menu
all possible combination I could think of.
NADA, NOTHING coming up. WTF is it?
Hardware mod is the only option for me I guest, but I just don't feel like doing it.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
I've just tested it and it works fine on my screen:
It doesn't have a serial no. on the back. But it's a version with the 10-pin connector like Gore- has.
The sound in VGA mode works perfectly now aswell, thanks alot!
Lilliput 7" TS / VIA EPIA M10000 / 256 MB DDR RAM / 40 GB 2,5" Toshiba HDD / TEAC DVD Slimline / GlobalSat GPS USB
Worked fine on my old lilliput, but I only have 6 digits. So I did: 001 1 1 1
Anyone know if it's possible to do on a TM-700TS, http://www.digitalww.com/TM700TS.htm
Is it safe to assume that you scroll through the "-------"s to input the numbers since pressing a number key saves the setting? I am assuming that this will work with my screen. It looks just like the TM-810VGT from DigitalWW except the pedestal is different. Same buttons and connector though.
I can't try this right now because I am in Iraq but I am documenting notes, suggestions, and ideas. I'm up to a 23-page Word document with pics.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
How many pins you have in your cable? 9 or 10?Originally Posted by Jeep
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Doesnt work on mine, I have the older version (din style connector)
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
It works! I don't think anyone has a monitor that is older than mine (2 yrs old with 9 pin connector) It so old even the serial number has rubbed off. I just played with it just as the above posts suggest. Never saw the "-------" line but did see the menu with "factory setting" header. I am not even sure what I did because there was no visual prompt but it now turns on and off automatically!
