Don't give up. Follow this link, read the post by "digitalww" post # 29. That is what I did. (BTW, factory setting appears as a header in the menu)Originally Posted by Custommx3
Auto Power On 619 Lilliput - Programing Guide
EDIT: It definitely works! Just went out and tried it again. These are the steps I took:
1- Power the PC and the lilliput
2- Enter the code 588998 – Do NOT use your finger nails! Use the tip of your fingers to make sure you push the buttons down all the way. Do it slowly, about one digit every two seconds.
3- A little window will appear on the bottom half of the screen with “___ ____”. The header will say “factory setting”. I was so excited when I saw this! On the “footer” of this window you will see the existing code.
4- Enter the codes that you want (see first post in this thread), making sure they are registered as you enter them.
5- Once done, enter any number to clear the window.
If you coded it to have audio in VGA mode, then do the following step:
6- Push on the Menu button. When Menu window opens you will see the header “factory setting”.
7- Navigate to Misc. setting
8- Set Volume mute to “off”
9- Press on Menu button to register this setting. If you don’t the mute will be turned back on automatically.
10- Navigate to exit and exit the menu
When you cut the power to monitor (turning it off will not do it) it will go back to regular menu.
I have a very old Lilliput with 9 pin din. It it worked for me, it will work for anyone. Just be patient. If it does not work the first time, cut the power to reset it, and try again. Also make sure you push the buttons all the way.![]()
LinkBack URL
About LinkBacks
