The power is what I disconnected.
Thanks, Todd
Thanks, Todd
This mod is to Auto Power ON not off...
was it suposed to auto turn off two ??
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status --> Lilliput Installed (not indash yet..)
BraveCar 2.5
Does the auto switching from VGA to AV inputs work too?
And I take it that for the 'audio + VGA' mode to work, you have to plug in that USB type A/V lead as well??..
Read all info, tested in my old Lilli, but don't appears the screen to digit the code....tested in all mode posted....Originally Posted by Zebelkhan
Work in old Lilli this function? (1 year and six months)
Mauri
After I coded the lilliput the thing would power up but then turn off a second later... It was frustrating because I had to use the remote to turn it back on (my screen is custom installed with no buttons visible). Then I rememberd that I had a tape put on the "on" button to keep it pressed in at all times. Removed the tape and it now works... Thought there maybe other retards out there with the same problem.
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
I tried a hundred times, really won't work for me![]()
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Same here.. and my lilli has NO serial number on it either.Originally Posted by Frankino
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
I only try 99 times and still didn't work. I give up.
When I pull the thing out to adjust the lame 9 pin DIN plug, I will do the RC method instead.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
