Page 5 of 14 FirstFirst 1234567891011121314 LastLast
Results 41 to 50 of 131
Thread: Lilliput Programming Guide, More Reset Codes
  1. #41
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    Quote Originally Posted by MatrixPC
    I only try 99 times and still didn't work. I give up.
    When I pull the thing out to adjust the lame 9 pin DIN plug, I will do the RC method instead.
    Admittedly, I still use the good ol' RC method myself
    I've only used the 588998 hack to enable VGA audio.
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
  2. #42
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    mine is a 8" panel, I haven't seen a rc mod for my panel and I'm not willing to mod without a precise guide and a LOT of positive feedbacks on the mod itself :P
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  3. #43
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Anointed - a big thanks to you for this... so how did you come by this info and are there any other Lilliput screens out there that other hacks... like the new in dash ones...
    Terran
  4. #44
    Bj
    Bj is offline
    Aug 2000
    Perth W.A Australia
    Something I found out the hard way...... Mine wouldn't bring up the factory code window unless I punched in the code "588998" whilst the "VGAMODE" was shown on the OSD (on screen display). Any other time it won't accept it. I didn't enter it slowly either, I have to enter it before the "VGAMODE" goes away.
    Just my 2 cents!
    Bj
    BjBlaster! Car MP3 & Carputer!
    bjblaster.com
    "The solution to one problem is only the beginning of another"
  5. #45
    Nov 2004
    Italy
    will try, thanks
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  6. #46
    Dec 2004
    Lilli reset codes
    Thanks Anointed for publishing the Lilli control codes and also for the webs site from viguera, http://www.viguera.net/carpc/, to get the code you want. It worked perfectly on my 619GL-70NP/C. No serial number, old case, but with newer screw style 10 pin video plug. Now, if I could just get it to display 800x480. All I get is a black screen on 800x480 with the modded BIOS and proper driver as described elsewhere on this forum. Still struggling with that before I give up.
    Louie
  7. #47
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by Louie928
    Louie
    Read somewhere on the forum that the black screen "might be" the sign of wrong refresh rate. Change it to see it makes a difference (i.e. to 75).
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  8. #48
    Nov 2004
    NY tri-state
    Louie
    FYI I just got a new lilliput from the mp3car store (whatever model that is) and this works perfectly with it.
  9. #49
    Variable Bitrate spyhunter's Avatar
    Jul 2002
    central jersey
    awesome work Anointed. one question, how the hell did you figure this out?
    Alex
    90 300zx twinturbo conversion
    Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
  10. #50
    Feb 2005
    WTF!!!!
    Tried everything.. read all the posts.. NOTHING! NADA. slow, fast, with VGAMODE on OSD, w/o..
    Ihave a lilli 619 10 pin. no serial on the screen. still. nothing.
    The touchkit has the ability to write functions directly to the EPROM, so, i'll try going that way. make the XP change the settings.. hard, i know, but i'm lost here. nothing worked.
    any idea guys?
    Omernesh.
  1. Auto Power On 619 Lilliput - Programing Guide
    By Anointed in forum LCD/Display
    Last Post: 10-23-2010, 06:26 AM
  2. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  3. Lilliput problem - Gain settings seem to reset
    By Cheater2k in forum LCD/Display
    Last Post: 09-29-2004, 06:26 PM
  4. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
