Page 6 of 14 FirstFirst 1234567891011121314 LastLast
Results 51 to 60 of 131
Thread: Lilliput Programming Guide, More Reset Codes
  1. #51
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    fast definatly wont work....and when you do it, theres a huge delay, so you do have to go pretty damn slow. have you reviewed digitalww comments on his tests? Try it several times. The first two times i tried it nothing happened. Lol, also check to see if your battery has life still (put it in your mouth).
    PC Components:
    My work log
  2. #52
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    Quote Originally Posted by omernesh
    The touchkit has the ability to write functions directly to the EPROM, so, i'll try going that way. make the XP change the settings..
    The touchscreen and its driver software are in no way related to the rest of the lilli -- they're completely separate pieces of hardware.
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
  3. #53
    Apr 2005
    County Durham, UK
    Works on mine too. No model/serial number but here's a picture.
  4. #54
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    it's a 2005 model, it's soo cool I have crappy blurry 2004 with no autopowerup software mod (
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  5. #55
    Constant Bitrate snmnetwork's Avatar
    Aug 2004
    Atlanta, Ga
    Quote Originally Posted by Jeep
    Worked fine on my old lilliput, but I only have 6 digits. So I did: 001 1 1 1
    [/url]
    Same here
    Status: [|||||||||-] 90% finished
    My 2000 Chevy Monte Carlo SS Install
  6. #56
    Aug 2005
    OKay I think I got it to work. Now when I power down the led stays green but the screen is off. And I checked too because I pressed menu on the remote and nothing pops up so I guess I finally got it right. So maybe this might help some people. I did everything above but still it wouldn't work but you have to slightly unplug the power cord and reinsert it. I think this basically executes the code entered. You can tell if it powers off because the screen will be pitch black and you can always press menu on the remote to see if it is turned off.
  7. #57
    Jan 2005
    i have the 619GL-70np/c/t
    i got the factory mode up but i only have 6numbers to inset?
    XXX X X X
    127 6 2 1 is current?
    how do i know the codes for the older one? i cant find them?
  8. #58
    Newbie Craigus's Avatar
    Aug 2005
    Australia Mate
    System: PIII 1000, 512 MEG SDRAM, 40GB 2.5" HDD, D-Link Wi-Fi, Morex 80W PSU, 7" Lilliput.
  9. #59
    May 2004
    Worked on mine on the first try. Don't have the serial handy as I already have the screen out of it's original case working on a custom enclosure for my 91 MR2 turbo. But it is the 7" lilliput w/ touchscreen I bought from the place in hong kong about 3 months ago.
  10. #60
    Oct 2005
    Power on codes
    We use the 619GL-70NP/C/T and the codes do work but....
    588998 to get the settings input displayed
    127 0 10 1 to turn on the auto power on
    5 to save - then WAIT
    5 to confirm save - then WAIT
    The unit then does a complete reset - and when it comes back the code is active. You may then need to reselect your video input source again.
    If you do not wait, like press the menu button/key or play with other buttons it seems to dump the changes.
  1. Auto Power On 619 Lilliput - Programing Guide
    By Anointed in forum LCD/Display
    Last Post: 10-23-2010, 06:26 AM
  2. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  3. Lilliput problem - Gain settings seem to reset
    By Cheater2k in forum LCD/Display
    Last Post: 09-29-2004, 06:26 PM
  4. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
