I'll test this coding on the new monitor I got. But on the last one, surprisingly it has auto on from factory. Unless....it was refurbished. err..
How the hell do you discover this kind of thing?
Hi!Originally Posted by Zebelkhan
I also have the 9pin-din lilliput. It's a newision NW619VT, a re-branded lilliput 619GL-70N/P/T.
I bought it on march 2004. I can't access to the factory settings.
I wrote an email to newision germany (the one who sold me the lilli) for have some infos about entering the factory menu.. Still waiting
Well, I think I'll go with the coyote mod!
bye
Guys I also have my lilly 629 (new model) working with the auto power on codes
question:
The brightness is set to max so everytime I need to down using the screen button to reduced the light intensity... is there a way to set this intensity with a code as default??
Also I noted the only butto iluminated is the power on.. and if i push the others (menu, or volume) they light but just for a few seconds.. is this normal??
Is there a way to have them all turned on always?
please advice
Hi!
I got response by newision
Why I have to buy another lilli when I could do a RC mod?The way to access factory setting are totally different between different monitors. We make this to protect our exclusive authorization technic. So sorry about this convenience.
If you really like this function as you mentioned in your letter. I suggest you buy our new NW619VT. We can make the special auto power on function for you. And I think the price for this special NW619VT will be much more competitive too. Pls consider.![]()
Anointed, can you please tell me how you find the code to access to factory settings? TIA
bye!
This thing doesnt seem to be working with the 629![]()
08 Lincoln Navigator www.mobiteklink.com
does anyone know if these codes work with the composite Lilliputs with built-in TV tuner? like the 718GL?
Originally Posted by MobiTekLink
The Lilliput model number only indicate what it look like outside. What mater is inside. Lilliput going thru many revision with the internal to make it better.
Mine doesn't work with the mod, but many other people got it works.
You can always do RC mod. Or if you like me, jam the power button (make it stuck down) and you have auto on. Easiest mod.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
You try it out and let us know.Originally Posted by bigdongers
More likely, none of us has that screen to try.
in case anyone is wondering, for the lilliput EBY701-NP the fifth blank is different for the lilliputs model # EBY701-NP... instead the 5th number you have to choose 2 in order to have auto power on. The code is mixed for these new lilliput models so instead you need :
0: Start with same mode as the mode before power is disconnected.
1: Start with Power-off mode when power is connected.
2: Start with Auto Power-on and standby mode when power is connected.
