works a treat here matemany MANY thanks.
not sure what the model number of mine is, because it's not on it, but it's a 7" widescreen lilliput![]()
Second that. Just did it on my 701 that arrived today. I had no problems doing it.
1. Entered 588998. OSD came up with --- - - -
2. Entered 097 0 2 0 (English, Chinese and Japanese as languages, English as default, Auto Power-On, sound in VGA, without tv input)
3. Once all numbers were entered, I pressed 5 (any button works) to close the OSD (on screen display)
4. Tested it by cutting the power, reconnecting it and voila! Turns on automatically when the power is connected...
Sweet!
I installed my carpc into my pet Kangaroo, mate.
I got the 629 I get it from mp3car.com I been try to get it on auto power on but I can't get not even to the factory set up and I been trying in every way I push the buttons slowly and all that but the factory setup don't come out.
Auto Power On New Lilliput - Programming Guide
You could try the following reset:
1.In VGA mode with your PC turned on (Recommended) , SLOWLY Input "588998" to come into the "factory setup" with the remote control unit.
is there another code for this particular model??
thanks!
One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
i can get into factory setup on mine... but i get menus not a line of numbers???
2001 Passat 130TDi Sport - Via Epia 15000, 1gb, 100gb, 220w psu, 7" lilliput motorized touch (chopped and in dash as a fixed), bluetooth, bu-303 gps, 7 port usb hub, tiny keyboard, netgear 54mb wifi, optima yellow top, ryder rt1170x, freecom dvb
Mine was the same way. I got a menu, but no place to enter the codes. I used my remote to type in the code needed to get into the system mode, THEN I pushed the menu button on the screen itself to get to a new more sophisticated list of options in a menu. One of the options in that menu was for the auto on. Good luck!
I found the way to doit and everything work good, but when I disconect the power and conect it again the monitor don't power on, still on stand by.
can that be because I don't got the usb cable connected to the pc.?
Its working... for somereason powered by the opus psu don't turn on but when i plug it with the cigarrete light adapter it turn on when recieve the signal.
I am hoping someone can help me out i have this screen http://cgi.ebay.com/ebaymotors/ws/eB...3450279&rd=1,1.
however when I enter the code i get a menu to choose the factory languages but that is it any help yould be great and I can post pics if that would help
I solved this a while back. When you get to the menu where it lets you switch languages, PUSH THE MENU BUTTON ON THE MONITOR ITSELF. It will give you a new menu with all sorts of options.
thanks you I will look into this when I put my psu back in car tomorrow
Thanks,
Yonu
