Results 1 to 5 of 5
Thread: Lilliput Display is Terrible - Are there Display Drivers for XP?
    Apr 2005
    I just installed my new 8" Lilliput touch screen, and since I also got the small cdROM, I downloaded the TS software from the sight listed here (4.0 version), and my TS works fine.
    HOWEVER, the display of the Lilliput is awefull - washed out white tint that will not change with the monitor settings. I still have graphics on the screen -(not just a blank white like mentioned on other threads), but it is all "washed" out in color. Is the any MONITOR DRIVER SOFTWARE (not TS) that I am missing that is specific monitor driver software for XP (again, my toch screen drivers work fine)? I had a cheap Hami 8" monitor which has a terrific display. This new Lilliput is "not" good, washed out regardless of changin settings on the monitor and XP. Is there any specific Lilliput monitor software avaialble since XP is only using "default drivers" for the monitor? Thanks!
    Maximum Bitrate dodgetimes2's Avatar
    MI
    If the monitor is good it will work display without any special drivers. The only software you need is the touchscreen driver. Sounds like you might have a loose cable somewhere.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Elsewhere
    No, there are no monitor drivers.
    And really, that's what happens when you buy a display that is a refurbished pachinko machine display....
    How about the Wiki?
    FLAC -zip-'s Avatar
    Ontario/Canada
    What happens when you try to calibrate it?
    Could be a loose wire, do the new ones still have the barrel plug thing, if so it could be a bad connection there as well.
    Mine had the same problem. Had to ship it back to lilli U.S.A and get a new one. Mine would not display the color red.
    Sound Stage
    Eclipse|MTX|Infinity
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    like everyone said the drivers will not do anything, you need to screw around with the settings on the monitor, make sure all 3 color settings are at around 33 and the brightness/contrast is correct, otherwise you have a dud monitor
    Signature: [==||========] 20% complete
  1. Lilliput Drivers for XP
    By Showmehow in forum Newbie
    Last Post: 07-21-2004, 11:18 AM
  2. rotate Lilliput display 180 degrees
    By tjb1231 in forum LCD/Display
    Last Post: 06-15-2004, 12:55 AM
  3. Display area of Lilliput 7in
    By bobbykokinos in forum LCD/Display
    Last Post: 03-17-2004, 09:49 AM
  4. WIERD Display on Lilliput...HELP!
    By Norrin302 in forum LCD/Display
    Last Post: 03-09-2004, 09:48 PM
  5. Small Lilliput display problem
    By Da_Teach in forum LCD/Display
    Last Post: 03-01-2004, 07:23 PM
