Results 1 to 10 of 11
Thread: how to wire lilliput into a molex
    May 2005
    Hi guys
    can you please give me some advice
    I have a lilliput touch screen monitor and want to cut the cigarette lighter plug off and attach the wires to a Molex connection which runs to my psu.
    when my carputer turns on the monitor will get power, how do I do this ?
    Cheers
    Constant Bitrate Willy-Mach1's Avatar
    Mar 2005
    Laurel, Maryland
    Doing some would do you some good, but here is your answer. The Lilli runs on 12v so all you need to do is to tap into a 12v wire from the PSU to one of the Molex connectors and do the same for ground. If I remember correctly of the 4 wires that go to the molex connector, the red is 5v the 2 black are ground and the yellow is 12v. The easiest way probably is to get the vampire clamps from the ratshack or any auto parts store (ie. AutoZone, PepBoys). on the lilli side, if i remember correctly, the white striped wire is the 12v and the solid black is ground.
    Progress: |##########| 99.99%
    - Tweaking and enjoying!!!! Never really done.....
    -= MachPuter Project =-
    -= MachPuter Project Worklog=-
    May 2005
    Quote Originally Posted by Willy-Mach1
    thanks for the replies
    I did do a search but couldnt find the answer I was after.
    I am in the UK so don't have those shops here. If I cut the littliput wire, will I only have 2 wires a positive and earth ?
    Is the white stripped one deffo positive ?
    Will I still need to use the 'egg' regulator thing ?
    cheers
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    the power off of your psu should be regulated...if it is..theres no use for the egg..if its not regulated..good luck with ur mobo...lol ....and use the egg
    Mar 2005
    Laurel, Maryland
    Quote Originally Posted by Froogle
    cheers
    Yes, there will only be 2 wires. I'm not completely sure about the coloring but if you have a multimeter it will be easy to find out. I am almost sure that I found the color coding of the wires somewhere here in the forums, check the "all you need to know about the lilliput" thread.
    as hanzacra posted... if you connect it to your PSU on a molex it should be regulated already so you don't need the egg, if you are hooking it up to any other 12v source I would keep the egg. What PSU are you using?
    FLAC -zip-'s Avatar
    Ontario/Canada
    Dont forget a fuse as well, just saved my *** about 5 mins ago.
    Sound Stage
    Eclipse|MTX|Infinity
    Raw Wave justintime's Avatar
    Apr 2005
    Quote Originally Posted by -zip-
    What fuse holder, and fuse type, do you use for this? Im actually running a Xenarc 700 TSV. I assume the fuse needs to be closer to one end of the cable, but not sure which one
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Apr 2005
    ABout to wire the Xenarc... would like some pointers regarding the FUSE. What size fuse to use, and also what type fuse holder you suggest?
    2002 Honda CR-V
    Variable Bitrate nsmoller's Avatar
    Dec 2004
    NY
    same model, i use 10 amp... you go buy a fuse holder at autozone or something, they have them, they go right inline... you should solder it inline!
    [4Runna]
    next - wifi
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    I made one of those for my lillipt, got the blank molex from maplin and the power adaptor with a pluggie from a boot sale ... see my reply in this thread here http://www.digital-car.co.uk/forum/viewtopic.php?t=1209
  1. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  2. Morex 60W car kit - 4 or 6 wire?
    By MVShibui in forum Power Supplies
    Last Post: 05-09-2005, 02:28 PM
  3. Did some mad testing on lilliput today.
    By kickercivic1 in forum LCD/Display
    Last Post: 10-18-2004, 08:51 AM
  4. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 07:58 PM
  5. Need to find acc wire that stays alive during crank.
    By Bobby Digital in forum Power Supplies
    Last Post: 02-05-2004, 06:42 PM
