Results 1 to 10 of 15
Thread: Is it room for another headunit? Golf IV
    Low Bitrate Stingah's Avatar
    May 2005
    Norway
    Question Is it room for another headunit? Golf IV
    I wonder if it is room for another headunit right over the original headunit and under the cup-holder. If i remove the little department. Reason i am asking is because I have just baught myself a TM702L and i wonder if i can put this in there so i dont have to remove the original headunit.
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    What are you asking actually?
    If that compartment is meant to be used for a 2nd head-unit?
    Who cares? It certainly wasn't meant for a fold-out screen, but that doesn't mean you can't use it just for that!
    It's the ideal place to put your screen, just check if it's deep enough... like many things in life you'll have to investigate that by going in!
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    I'm sure you could...
    Mar 2005
    Maryland
    Thats a Double-din...with a strange shaped storage thing, theres defently PLENTY of space behind it.
    May 2005
    Norway
    I just thought that maybe someone has made this mod before
    I have tried to investigate a bit I took some measures and found out that the size was almost the same, but the question is: is this space ment to be used for it? If it is it would probably ease my work alot!
    Dude, i'm just conversationing
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    :-P yeah man just stick it in if it dont fit then take it out and try it again hahah
    Constant Bitrate john_draws's Avatar
    Jun 2004
    a radio or pullout screen will fit in that slot.. I also have a gti so i am positive it will fit, I have completly taken everything out of my car so if you have any questions about the car i can help. I know the pullout screens are deeper then normal din slots. so im not sure of the depth but if you give me depth of the screen i can measure inside the dash for you cause i am gettin ready to redo my dash install. if you want you can check out my install thread.
    Clean GTI VR6
    Now in that thread you are going to see some pics of the dash ripped apart so that should give you an idea of what is going on behind the front bezel. But in yours will look a little different because i did some extreme modifactions to the front bezel mounting brackets.
    As i said any help you need i would love to help another vw owner out. And on a side not when it comes time to run power from the battery you are in luck because there is already a 8 gauge power wire running into the cabin of the car that is unused. Check the pic you will see what im talkin about.
    Mar 2005
    Maryland
    yeah, a single-din is a single-din...wtf, Fort Detrick is having yet another fireworks show for no reason...
    May 2005
    Norway
    Quote Originally Posted by john_draws
    Clean GTI VR6
    Great! I guess i will recive the monitor tomorrow. So i can reply you with the measures then. But it would be exelent if it would fit in there!
    Where are the 8 gauge power-thingy located?
    Jun 2004
    In the picture I posted in my above post you can see (30a i think) does not have a relay in its slot. That is a 8 gauge wire coming straight off the battery.
    I was also wondering why you dont just configure your computer in the house.
  1. Lilliput and golf IV
    By gup133 in forum LCD/Display
    Last Post: 09-26-2004, 06:21 PM
  2. VW Golf IV GTI monitor Position
    By sandroad in forum LCD/Display
    Last Post: 08-03-2004, 08:06 AM
  3. VW Golf IV multimedia-car 2002
    By Fluffy in forum General MP3Car Discussion
    Last Post: 11-14-2002, 08:00 AM
