Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Screen "flickers"
    Low Bitrate Stingah's Avatar
    May 2005
    Norway
    Question Screen "flickers"
    I dont know what it is but my lcd flickers alot. Can this be elecric noice?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Change the refresh rate to about 75 hertz.
    Power the screen from the PSU and not the cig lighter.
    May 2005
    Norway
    i powered the screen from the cables to the stereo... isnt that ok?
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Stingah
    Umm.... there's a lot of cables. You're telling me you powered it with the speaker wire?
    Hook it up to the PSU. You'll get better quality. Also change the refresh rate.
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    reset your screen
    place it on 75hz and power it by PSU
    it should solve
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    May 2005
    Norway
    Ok. Then i have to put some more wires from the trunk.. damn. I took the 12 v. wires from the stereo-kables.. it should be ok. But why shouldm i take power from the psu? whats the diference? I could not adjust the hz anymore. Its only 60hz.
    FLAC evandude's Avatar
    Mar 2005
    Maine
    Because raw 12v lines in the car have noise on them, it is not a clean 12 volts. Any noise that is on that line will also end up in the power supply of the screen, and cause flickering. When you power it off your PSU, you are getting a well-regulated, clean 12v.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    May 2005
    Norway
    OK, i did as you told me.. and now the screen wont start again. The image only flashes on and then it swiches of again. It's like if it doesnt get egnough power. please, someone help me!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i've noticed when i hooked my screen to my psu the damn thing was barely bright enough to read. I've got it hooked to teh battery now fused and with the egg and its perfect even in direct sun.
    May 2005
    Norway
    yes, but mine shuts down after like 1/2 second.
  1. Replies: 37
    Last Post: 03-19-2010, 02:08 PM
  2. Replies: 4
    Last Post: 01-29-2005, 07:35 PM
  3. Replies: 5
    Last Post: 04-30-2004, 12:25 PM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  5. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
