Results 1 to 8 of 8
Thread: composit/phono vs. s-video
    Low Bitrate Stingah's Avatar
    May 2005
    Norway
    Question composit/phono vs. s-video
    My screen flickers ALOT, will it work to use s-video insted of the thin phono/composit-cable i am using today?
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Screen flicker is generally caused by something electrical.. Try a different RCA cable first, then SVideo. You aren't guaranteed no-flicker by any type of connection.
    Newbie 66miles99's Avatar
    May 2005
    Canada Eh!
    Just my 2 cents but I've read here that flicker is often a power source problem more than input signal.
    Dell C600 laptop
    Dell C dock II
    7" Lilliput VGA TS
    JVC Mp3 Headunit
    Holux GPS
    ...Its all working now in the car but far from complete.
    [|||............] 35%
    May 2005
    Norway
    it does not flicker at the "no-signal" screen
    Elsewhere
    Quote Originally Posted by Stingah
    No ****. If the monitor is working properly, it won't flicker, since this is generated within the monitor.
    Someoen suggested trying a different cable and checking all the connections, as that's the most likely culprit.
    How about the Wiki?
    May 2005
    Norway
    but cables costs.. i cant buy like 10 diferent cables and try..
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Any thing else is probably more expensive to correct.
    1. Cables
    2. Power fluctuation
    3. Electrical interference. (better cables sometimes help to eliminate this. Check you are not running power near the signal cables)
    4. Loose connections (cabling or inside the monitor)
    5. Battery/Alternator may be struggling to provide the screen with enough juice, this could be down to the thickness of the power cable or.
    That should keep you busy for a while
    Elsewhere
    Welcome to life, amigo. Nobody ever said this hobby was going to be cheap nor easy!
    I hear the same bull**** from clients.
    Me: You've got a failed <whatever>.
    Them: That means I need to buy a new one.
    Me: That is correct.
    Them: But that costs money!
    Them: There's no way it can be fixed? What about reloading Windows?
    Me: You've got dead hardware. You're going to need to reload Windows anyway when the hardware is replaced. It won't do a thing until then.
    <ad nauseum>
    How about the Wiki?
  1. Extreme video playback choppyness with HVAC software
    By Dexter in forum Software & Software Development
    Last Post: 04-11-2005, 02:24 AM
  2. No auto resume music and video?
    By organasised in forum Road Runner
    Last Post: 02-10-2005, 10:55 PM
  3. Custom Video Switching Device
    By mbkowns in forum General Hardware Discussion
    Last Post: 07-14-2004, 01:10 AM
  4. Media Car video player
    By MatrixPC in forum MediaCar
    Last Post: 03-22-2004, 01:33 PM
  5. Weird problems with video and ME 2.1
    By Rireal in forum Media Engine
    Last Post: 02-20-2004, 07:33 PM
