Results 1 to 6 of 6
Thread: DWW-7VGA screen flickers =/
    Nov 2004
    boca fl
    I seem to be running into an issue with my screen, i have the car running and i boot the computer and i get white horizontal lines on the screen, sometimes seems random other times seem to go faster when the car moves faster. It also only happens on top portion of screen. Then slowly after some time the screen itself starts to get brighter and brighter. I dont know what it is, i took apart the vga connection to comptuer, still happening. I fiddled with the ground and power cable, no reaction to screen.
    This whole thing is soo random, because i had it working b4 i connected it to computer. It was connected to my digital camera and it was working, flawlessly. Now I am lost confused and ****ed. HELP ME!!!!!!!!!!!!
    -Mike
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Coon Rapids, MN
    grounding..
    ground your case with the thickest wire you cna find.. and make sure you LCd is grounded well..
    I've alsfound getting a better VGA extention cable helps .. better than the one that comes with it.. there is litle shielding a weak grounds in the stock one that coes with the screen..
    what you're getting is EMI, or alternator noise.
    Shawn
    I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
    Check out my web company Minneapolis Web Designer - Himmelberger Design
    Nov 2004
    boca fl
    i fiddled with it some more and it seems as the wire going into the screen itself causes the flickering. If i move the wire the screen white line flickering either goes more worse or gets all better.
    I am wondering can it be a poor sodering inside? maybe something loose?
    FLAC -zip-'s Avatar
    Ontario/Canada
    Sounds like you found the problem.
    Sound Stage
    Eclipse|MTX|Infinity
    Nov 2004
    boca fl
    ... tell u tommorw if i really did
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    any luck finding out why you get the noise? im having the same prob with my lilliput 7"... thanks
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  1. Replies: 37
    Last Post: 03-19-2010, 02:08 PM
  2. Anyone care to help me with a mystery screen?
    By Rover_Eli in forum LCD/Display
    Last Post: 03-27-2007, 08:34 PM
  3. Replies: 4
    Last Post: 01-29-2005, 07:35 PM
  4. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 07:38 AM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
