Results 1 to 10 of 11
Thread: Lilliput often needs calibration
    Low Bitrate cyrix^'s Avatar
    Feb 2005
    Denmark
    I have a problem with my lilliput touchscreen....
    Often when I start the carpc the lilliput needs calibration...
    Why ? It just started to this a few days ago when I reinstaller det lilliput....
    Anyone have any ideers ?
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    What kind of touchscreen do you have? Is it USB or serial? I ran into all sorts of calibration problems with my touchscreen until I plugged it into a real serial port rather then my serial to USB converter.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
    Feb 2005
    Denmark
    It is a usb, and connected directly to usb..
    It needs to calibrate when i loads windows... So i actually think it is the drivers that are causing the problems...
    FLAC J187's Avatar
    Nov 2004
    Boston
    and you are not changing the resolution, correct? Try reinstalling the drivers.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Feb 2005
    Denmark
    Quote Originally Posted by J187
    Nop.. I've installed with the beta drivers.. Think that might be the problem. But I have installed "stable" drivers now.. I will report back with status..
    But it is indeed the drivers that are causing the troubles somehow!
    Tainted Love Cris's Avatar
    Romania
    Yes, the drivers cause this. Unistall and reinstall again the newest drivers you can find.
    Feb 2005
    Oklahoma
    I installed teh latest drivers and it started this, I guess I will try the drivers from the disc and see if it goes away.
    Constant Bitrate studmonk3y's Avatar
    Feb 2004
    Honolulu, HI
    yea i had this problem too, it's the drivers. Use the 3.2.3.3122 drivers.
    Romania
    I remembered, you get this kind of error when the drivers are not fully or properly installed. You enter the 25 point calibration, do it, and when you exit it, you get an error...if this is the case for you, reinstall the drivers until the 25 point calibration works, and you'll have no problems then.
    Feb 2005
    Denmark
    Nop. no errors.. Just the beta drivers that sux i think.. I haven't been able to test it yet. Having some other issues with the carpc at the moment..
  1. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  2. Lilliput Calibration WAY off
    By ismell in forum LCD/Display
    Last Post: 06-08-2005, 02:21 PM
  3. Replies: 11
    Last Post: 11-15-2004, 09:30 AM
  4. Lilliput 4-point and 25-point calibration?
    By chris in nh in forum LCD/Display
    Last Post: 06-20-2004, 02:16 AM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
