Results 1 to 4 of 4
Thread: help me with my fuse
    Mar 2005
    i was able to get the fuse off my lilliput, but im having a hard time gettin the new one on...every time i remove the iron from the solder it immediatly hardens so i can place the fuse down in time...i tried adding extra solder but it doesnt make a good connection by just goin around the sides so i donty know what to do...any help?
    thanks
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    what you need to do is clean the excess solder from the pads, then lay the fuse onto the pads. Place the tip of your soldering iron onto the pad, hold it there for a sec. You should see the solder melt and bond the pad to the fuse. If they dont bond, then add a very small amount of solder. Then let the first side cool for a sec then repeat for the 2nd side.
    肚子笑痛了
    S60 Install
    Mar 2005
    should i use a sesoldering braid?
    May 2003
    Miami, FL
    no because it will take too much solder off of the pads, if you wipe the tip of the soldering iron with a damp towel and touch the pad, that should take enough off to work.
    肚子笑痛了
    S60 Install
  1. Fuse popping, wire heating up!
    By gumbi4u in forum Power Supplies
    Last Post: 06-29-2006, 11:01 AM
  2. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  3. Lilliput Lcd fuse blown help!!!!
    By fernando11554 in forum LCD/Display
    Last Post: 05-16-2005, 12:54 PM
  4. Xenarc fuse and power help required
    By Scouse Monkey in forum LCD/Display
    Last Post: 02-18-2005, 03:45 PM
  5. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
