Results 1 to 9 of 9
Thread: weird lcd problem
    May 2004
    weird lcd problem
    ok yesterday i went to turn my carputer on and at first all i got was a black screen. then it came on and worked for a while but then the screen went blue and from around the outside it turned white and the white slowly crept toward the center. so i shut it off and started it again and it worked fine. but it did this twice. any ideas what caused this? also, yesterday while i was driving, for about 10 min whenever i would hit a bump my touchscreen would activate and it would restart the song i was listening to. but then it stopped. any ideas what caused this? thanks.
    Raw Wave
    Jun 2004
    On the beach
    The bluescreen thing sounds like what I have now and again. It is the connection between the button control strip and the LCD controller working loose.
    May 2004
    what do you mean working loose? i just got my screen this past wed.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    how are you powering the screen?
    肚子笑痛了
    S60 Install
    May 2004
    off of my computer's power supply
    May 2003
    Miami, FL
    Well mine does that sometimes, I have found that it is just a loose ribbon cable, did you take the screen apart at all? Also are you running anything else off of the line you are powering the screen with? What power supply are you using for your computer?
    肚子笑痛了
    S60 Install
    May 2004
    jcdillin - what problem are you talkin about the touchscreen one or the blue and white problem? no i haven't taken my screen apart. either the cd player, or the hard drive are on the same power line. im using the atx 1123b power supply. any suggestions how to fix either problem is greatly appreciated. and both only happen at random times so they are really hard to figure out. thanks.
    May 2003
    Miami, FL
    the blue and white problem, well what might be happening is that you are drawing too much from the power line, because when the lilliput doesnt get enough power it will do strange things like that
    just as a temp solution you might try powering the screen from the cigarette lighter plug that came with it for a few days and just see if the problem continues, if it works fine then you have found your problem.
    I am not sure about the touchscreen issue, I would check out the latest drivers from the lilliput thread in this forum, might fix your problem
    肚子笑痛了
    S60 Install
    May 2004
    anybody have anything else?
  1. LCD fuzzyness problem...???
    By citrus3000psi in forum General Hardware Discussion
    Last Post: 08-20-2006, 08:49 PM
  2. LCD problem
    By mosh in forum LCD/Display
    Last Post: 09-15-2003, 07:23 AM
  3. Weird Hitachi LCD Laptop Screen
    By Andrew Chappell in forum LCD/Display
    Last Post: 01-30-2002, 05:41 AM
  4. LCD backlight problem
    By UltraMan in forum LCD/Display
    Last Post: 11-10-2001, 10:54 PM
  5. Serious LCD problem! HELP!!!
    By embedded in forum Software & Software Development
    Last Post: 03-28-2001, 01:14 PM
