Results 1 to 9 of 9
Thread: 700TSV - REAR VIEW CAMERA?? anyone have this monitor?
    May 2005
    hey i have a lilliput (the NEW model right now) i want to sell it and get a xenarc cause i was told they will auto switch to a camera...
    my question is this...
    if your using the VGA input at the time that you go into reverse, will the monitor still switch into the Rear Camera Mode or RCA input mode?
    which one takes priority? or is there some kind of wire that tell is to switch?
    im not liking how i cant find a way to make my lilliput switch into reverse camera mode by itself...
    i have the NEWEST version of the lilliput, unless someone knows how to make it do it?
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    http://www.startech.com/ststore/item...=COMP2VGA&mt=Z
    its basically a cheesebox... and its a LOT cheaper than a Xenarc
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by Netrave
    I don't think they auto switch. In my experience if you have only the VGA cable hooked up with a signal going to it and the display is set to AV1, it will still stay on AV1 if there is a signal or not.
    What the xenarc does is automatically turn on and off if there isn't a signal so if you have both a VGA and AV1 hooked up with signals and the display is set to AV1, when you kill just the AV1 signal, it will shut off, not switch to VGA.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Aug 2004
    Pearland
    you are correct it doesnt autoswitch... but if you wire up a SPDT relay to the switch... you can make it switch when you put your car in reverse...
    Constant Bitrate gizak's Avatar
    Feb 2004
    Phoenix, AZ
    First off, you should try searching as this question comes up a lot.
    Second, I'll answer your question about Xenarc cause I'm a nice guy.
    XenarcTSV has 3 video inputs: VGA, AV1, AV2. (AV's are the RCA inputs)
    AV2 is the "autoswitch" input.
    Plug VGA into computer, Plug Reverse camera into AV2.
    Toggle auto-switch on for AV2 on Xenarc.
    If computer is on, and reverse camera is off, VGA shows (duh)
    If computer is on, and reverse camera is on, xenarc senses camera is on and switches to AV2.
    Basically Reverse Cam (AV2) > Computer (VGA)
    Once you turn off Reverse cam (AV2), Xenarc will return to last input it was at (usually Computer/VGA).
    bonus: anything plugged into AV1 will require you to manually change (via source button).
    -GiZak-
    Carputer Project: 98% Complete!! *tweakin'*
    Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Thanks gizak.
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    I can also confirm that the xenarc's do auto switch on AV2
    Nov 2004
    I just wired up my reverse cam to the AV2 input on my new Xenarc.
    I don't have a VGA input because my carputer isn't installed as of yet so the Xenarc stays in "standby mode" with the green light flashing. When I put the car in reverse the Xenarc doesn't come on and show the AV2 input automatically!?!
    The AV2 first is selected and if I turn the monitor on and have it sitting on any input it will then auto-switch to the AV2 input for me... but I need it to turn on the Xenarc when I put the car in reverse. Help please!
    Dec 2004
    Miami, FL
    So how do you have the rear-view camera only on and sending a signal when the car is in reverse?
    A car without turbo is a car with perpetual lag.
    My Ride
    My New Page
  1. 120 deg Wide-Angle Rear View Reverse Camera off Ebay - REVIEW
    By tbird2340 in forum The Review Palace
    Last Post: 01-11-2005, 04:30 PM
  2. Rear view camera and dazzle usb
    By muldrick in forum Input Devices
    Last Post: 11-06-2004, 03:32 AM
  3. rear view camera
    By lasteclispe in forum LCD/Display
    Last Post: 10-21-2004, 11:00 AM
  4. FS: 5" Rear View Mirror monitor!
    By DLe in forum Classified Archive
    Last Post: 09-30-2004, 09:57 PM
  5. Have video camera for rear view - which program?
    By nxt125 in forum Software & Software Development
    Last Post: 08-15-2002, 12:25 AM
