Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 52
Thread: Nice little infrared hardware hack for Lilliput owners
  1. #21
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    Quote Originally Posted by Peoples
    i really dont understand what the fuss is all about making girder work......i think its a very intuitive very easy to use program
    Almost just as easy as hooking up that IR eye
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
  2. #22
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    I can't figure out Girder. I used the included Ir program, and it worked, but it thought every button was the same. The LED's in my IR receiver showed up (so it was connecting to COM1), but it wasn't receiving any data. I'm thinking if I gut the IR reciver and add one of those circuits, it might work.
  3. #23
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    please forgive the super noob when it comes to serial port wiring but i'm having trouble reading the above diagram. According to what i see pins 2 and 4 dont connect to anything? and the connected pins are 1 & 3, 7 & 8, 5 & 9? Then 5 & 9 are both connected to ground... correct? I just wanna be sure before i end up fryin components.
  4. #24
    mox
    mox is offline
    Nov 2004
    The Netherlands
    Quote Originally Posted by Sonicxtacy02
    Correct.
    Yes. Crossing lines don't touch each other, unless the crossing is a dot.
    Hope this helps -- good luck!
    Software: RR, MM/FD
  5. #25
    Woodbridge, VA
    Blog Entries
    32
    thanks. Cant wait to get this accomplished now! I've got girder all set up!
  6. #26
    Woodbridge, VA
    Blog Entries
    32
    anyone else getting the error "unable to inicialize usb driver dll library" with the igor plugin? I've searched the net for solutions and i cant seem to find one.
  7. #27
    Woodbridge, VA
    Blog Entries
    32
    nevermind.. had to configure the plugin thru girder.
  8. #28
    mox
    mox is offline
    Nov 2004
    The Netherlands
    Yeah, it's a matter of selecting COM1 or 2 instead of USB.
    I have just finished installing Girder on my MII-12000 based carputer (earlier testing was done on laptop) and it works fine. What is the latest and/or most complete GML-file for RoadRunner?
    Software: RR, MM/FD
  9. #29
    Woodbridge, VA
    Blog Entries
    32
    there's a sticky in the road runner section with gml's. Dont bother downloading mine its probably a little too basic.
    One LAST question on doin this. Now granted i havent cracked opened my lilli case, but i was wondering if i already have my infrared sensor remotely mounted, can i just splice into those wires instead of soldering directly to the board? This would save me alot of time and prevent having to crack open that touchy case again.
  10. #30
    May 2005
    Mox can this be used without the screen ie; If I can buy just an eye and have it connected to the serial port?
    Also...where can I get an eye?
  1. help with a hardware hack!
    By hijinks21 in forum Off Topic
    Last Post: 10-27-2007, 03:07 AM
  2. hardware not playing nice
    By cyber in forum General Hardware Discussion
    Last Post: 07-27-2004, 11:13 AM
  3. Couple of nice Hardware Sites...
    By hansolo77 in forum General Hardware Discussion
    Last Post: 06-26-2003, 09:04 AM
  4. Nice info for FV24 owners.
    By moahdib in forum Software & Software Development
    Last Post: 02-14-2002, 02:12 PM
