Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
Thread: Nice little infrared hardware hack for Lilliput owners
  1. #31
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    Quote Originally Posted by Sonicxtacy02
    there's a sticky in the road runner section with gml's.
    Found it, thanks. (duh )
    if i already have my infrared sensor remotely mounted, can i just splice into those wires instead of soldering directly to the board?
    As long as the sensor remains connected to the lilli, you will be fine -- just think of the eye as a switch that periodically connects the comport's DSR line to ground level when "fired" upon with a remote (as can be seen on the scope image earlier in this thread). I would use shielded wire, although interference is highly unlikely at these frequencies.
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
  2. #32
    mox
    mox is offline
    Nov 2004
    The Netherlands
    Quote Originally Posted by Letsride
    Mox can this be used without the screen ie; If I can buy just an eye and have it connected to the serial port?
    Sure, the "Igor plugin" comes with a little schematic. To view, click on "About HW" in the plugin's settings window.
    Also...where can I get an eye?
    Um, Radio Shack I guess
    Software: RR, MM/FD
  3. #33
    May 2005
    Thanks....gonna pkay around with some ideas..
  4. #34
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    ok got it hooked up and working with girder. but girder detects every button on the remote as the same code. Anyone gotta fix for this?
  5. #35
    mox
    mox is offline
    Nov 2004
    The Netherlands
    Does the lilli itself still respond to its own remote (on/off, menu, AV/TV)?
    See if the right half of the schematic in your version of the Igor plugin matches your comport wiring. Earlier versions of the plugin come with a slightly different diagram -- the link between DCD and TxD is essential.
    I'm using Girder 3.2.9 and Igor 4.04
    Software: RR, MM/FD
  6. #36
    Woodbridge, VA
    Blog Entries
    32
    i got it working with a old ps2 dvd remote. The other remote was the problem. it sent the same signal for every button until you changed the source (tv,dvd, etc). I've had to try it with 4 or 5 remotes to find one that sent a clear signal for each button, but its workin great now! Wish i hadda remote with more buttons than this one but its better than nothing.
  7. #37
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    incorrect URL
    Hi guys,
    If your turned on by remote controls, checkout the ondigital remote and IR buddy. If you can solder, by cutting off the end that comes with the IR buddy and rewiring (Wiring changes ) you get a remote control with full qwerty keyboard inside, which you can programme using girder as your keyboard. I have exchanged mails with Andy from Digibox, as he was interested in doing the mods and selling the finished item to those who are interested.
    The item I purchased can be found at Remote and IR Buddy
    Make sure you check that your purchase includes the IR Buddy, as he sells the remotes without as well (and I made that mistake ops: !)
    Once you have done that, it is a case of getting girder to recognise the commands and away you go. I have not yet completed the recognition of all the keys yet, but I believe that others around these forums have. I just need time to get around to it. If only her indoors didn't want to go to Ikea this afternoon . . . . . .
    At least you won't have to prise open you lilli !
    cheers KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
  8. #38
    Nov 2005
    FL
    do you have pics of this and your IR sensor mounted>?
    CLICK ME FOR BMW CARPUTERS
    95 Avus M3
    Mods: ;-)
    Carputer: Lilliput 619, GPS= LT-20 Receiver, IGuidance 3 & Streets & Atlas 2K6, RR Front End, Removable Dell Inspiron Laptop, More to come........
  9. #39
    Oct 2006
    Bear, DE, USA
    I've been doing this on my living room PC for years...it costs like $8 in Radioshack parts, and you can use Winlirc and autoHotKey scripts to control everything from DVD software to volume, etc., from the remote of your choice. You could even script it so that you could adjust your touchscreen brightness, contrast, screen position, etc, from...(drumroll please)...your touchscreen, or use an old remote to re-code button presses on your factory steering column for your PC, or create a custom controller mounted in your center console...the possibilities are endless.
    I have too much time and too little aggravation in my life, so I built a carPC. ;)
  10. #40
    Nov 2005
    FL
    never knew that. I think I might want to try this. In all honesty, how long would it take for someone with little soldering skills to complete this install?
    95 Avus M3
    Mods: ;-)
  1. help with a hardware hack!
    By hijinks21 in forum Off Topic
    Last Post: 10-27-2007, 03:07 AM
  2. hardware not playing nice
    By cyber in forum General Hardware Discussion
    Last Post: 07-27-2004, 11:13 AM
  3. Couple of nice Hardware Sites...
    By hansolo77 in forum General Hardware Discussion
    Last Post: 06-26-2003, 09:04 AM
  4. Nice info for FV24 owners.
    By moahdib in forum Software & Software Development
    Last Post: 02-14-2002, 02:12 PM
