Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: Grrr, why does my Xenarc Brightness and contrast keep reverting to 33 when I shut dow
  1. #11
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    keeping constant power is a possible workaround, not a solution...
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  2. #12
    Sep 2003
    Thousand Oak, Ca
    I have mine hard wired to full time 12v, it still reverts to the 33 brightness once a week or so. Once I had it lock up with a blank screen. None of the buttons worked includding the power button. I had to pull my dash cover to remove power to get it working. If you wire it up to have power all the time, you should have a way to kill power to it if you need to.
  3. #13
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by mskrzat
    You should have a fuse near your power source...This would suffice.
    500+ full albums
    4,000+ video games
    old carPC
  4. #14
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Do they replace the whole screen, or is it just a firmware update?
  5. #15
    Jul 2004
    Quote Originally Posted by XxAndyxX
    It is just a firmware update
  6. #16
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by yunusyu
    Remedies:
    1. Make sure the power is always connected to the battery...a constant 12v. The screen will turn off when the computer is off.
    I suppose I could try this as my screen is currently powered off of my M1-ATX (which cuts power after 2 hours).
    But my only concern is sending good, clean power to the Xenarc so that I don't fry it. That's why I put it behind my M1-ATX.
    Would I need some kind of voltage regulator if I power the screen separately?
    500+ full albums
    4,000+ video games
    old carPC
  7. #17
    Constant Bitrate JPuma's Avatar
    Jul 2005
    NY
    I had a similar question ITL. Is it recommed to power the Xenarc with regultad power or is the cars 12V good enough. I mean they do provide you with the cigarrette lighter but just wondering if I should take it to the next level.
    Also, if and when you turn off the xenarc and the it loses power to the touchscreen does than mean its an older model, or is that the design of the newer models as well. I just purchased a xenarc, Ill have to test the brightness issue. Is it only with the video inputs or VGA too?
    I also have one dead pixel. My wife thought I was crazy when I was complaining about it but the VGA can be returned easily, it not moleded into anything yet.
  8. #18
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    well, I'm not sure they'll let you return it for one dead pixel. I believe I read somewhere that it is guaranteed 99% pixels or something along those lines. Call the mp3car store. I bet they can tell you.
    My brightness reverts to default on the VGA only rarely. With the composite line, it lost settings every time the device was disconnected or powered off.
    500+ full albums
    4,000+ video games
    old carPC
  9. #19
    Jaz
    Jaz is offline
    Apr 2005
    my lilliput does this, no one knows how to fix it tho stuck with it i guess.
  10. #20
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    just installed my rearview camera on AV2. brightness settings get reverted to 33 when it switches back to PC as well. I guess I'll be pulling the screen out soon to return it...
    500+ full albums
    4,000+ video games
    old carPC
  1. setting screen brightness and contrast permanently
    By G35Pimp in forum LCD/Display
    Last Post: 07-27-2007, 08:54 PM
  2. Xenarc contrast and brightness settings
    By Scouse Monkey in forum LCD/Display
    Last Post: 04-27-2005, 07:34 AM
  3. Contrast Ratio on Liliput and Xenarc???
    By sxt173 in forum LCD/Display
    Last Post: 03-12-2005, 04:03 PM
