Results 1 to 10 of 10
Thread: DWW - 700M : not opening
    Constant Bitrate John_Duh's Avatar
    Feb 2005
    Belgium
    hello guys,
    This weekend my screen arived ... but as the title already suggests, i couldn't open the screen.
    I powered it off an ATX PSU from my computer and it turned on perfectly. I could set the time on the small display, but when pressin the open-button nothing happened. Oh yeah, i fed it a display signal off my laptop through the 15 pins connector cable that came with the display.
    Any suggestions ? Did i miss something ?
    '02 Toyota Celica TS
    Carputer progress : [#######---]
    Currently working on : software ...
    Parts : IBM thinkpad X60 wired up in the booth (T7200 - 1.5Gb Ram - 320GB HD)
    Parts needed: USB wifi dongle (with external antenna)
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    someone posted something similar, you have to connect the red and yellow wires that arnt connected to anything to themselves i think, its for a handbrake sensor so you can use the screen while your driving.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Feb 2005
    Belgium
    can you be a bit more specific ... or maybe give me a link ?
    I did a quick search but couldn't find it (and since i'm at work i can't search for hours)
    On the screen's power connector there are 4 wires
    - 12V (yellow)
    - ground (black)
    - earth (red)
    - lighting signal (green)
    From your reply i undestrand that i should connect red and green together. Correct ?
    TIA
    Raw Wave
    Jun 2004
    On the beach
    by the looks of it put black and red together, check the manual, it all depends on how the screen connects to the handbrake for its signal
    Feb 2005
    Belgium
    The manual says ground or something crypitical for the red wire. I'll give it a try as soon as i get a chance.
    Thanks for the help
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    OH, MY , GOD. First of all, no one so far seems to know what they are talking about, including the original poster.
    Quote Originally Posted by dan__wright
    Somewhat correct, but nope.
    Quote Originally Posted by John_Duh
    - 12V (yellow)
    - ground (black)
    - earth (red)
    TIA
    Your wiring color is wrong. Green is no a "lighting signal"
    Quote Originally Posted by UK_MP3Car
    While somewhat correct, when was the last time someone had to connect Black and Red to the same source. Convention dictates Black is ground, and Red is power. I realize you were using JDs wiring diagram for that statement, but still.
    Phew, now I feel better.
    The wires are Red, Yellow, Black, and Green.
    Red is constant power, Yellow is accessory power (12 volts when the car is running, and nothign when the car is off), Black is ground, and Green is the handbrake switch.
    You must ground the handbrake switch wire to get the unit to work. It can be connected to the Black wire, and both grounded to the same place if you like. Yellow and Red CAN be connected to the same 12 volt source, but they should be connected correctly to operate correctly. If you are just testing the unit, don't worry about it. The red supplies power to the unit all the time, that way when the Yellow wire loses power (From turning off the car) the unit still has a power source to close the screen.
    Please, if you are unsure about something, state it is such, or research the answer. Just blindly giving advice can lead to trouble. And John, . While I agree that the manual isn't the greatest, the only real question is the green wire. Red, Yellow and Black are both explained in the manual, and pretty self explanatory.
    Michael
    Sorry for the rant, just don't want him to screw up his unit.
    Also, you can check out my 700m modification thread at Modding the new Motorized VGA Screens
    Feb 2005
    Belgium
    Quote Originally Posted by Wiredwrx
    Michael
    uhm ... well .. i did the RTFM thingy, but couldn't figure it out. And for the moment i really don't have a lot of time to try to decifer something cryptical like this manual. So I went for the easy option (you can flame me for it, but that's what i did)
    And yes, i got the wiring colors wrong, but that makes two of us. The manual states that Yellow is constant power while red is switched. (or at least that's what i understand when they say "+" battery)
    Anyway, Arwen jumped in and sent me a PM, so here is the correct connection for testing purposes to a normal ATX-PSU
    yellow + red -> yellow PSU wire (12V)
    black + green -> black PSU wire (GROUND)
    don't know if it matters which ground you use, but i took 12-ground
    Guess for in-car purposes that the connection should be as follows:
    yellow -> battery +
    red -> switched 12V
    black -> ground
    green -> ground (or handbrake if you don't want to open your screen while driving)
    Thanks to Arwen for his support in this matter
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    yellow -> battery +
    red -> switched 12V
    black -> ground
    I apologize for confusing the Red and Yellow. I was going off memory. I just wanted to make sure you didn't connect red to ground, and green to +, cause that would undoubtadly have caused a problem in the unit, and certaily. black and red together to a positive source would have had the same ending, a broken unit.
    Did you get it to work?
    Michael
    Feb 2005
    Belgium
    Michael
    Same here (going off memory) ... seems we both need an upgrade
    Yes, I got it to work ... now i only need to get my software sorted out and i can start thinking about installing it in my car
    thanks for the support guys
    Jun 2003
    Raleigh, NC
    This seems like a very knowledgable group regarding the DWW-700M. Could you please check out this thread and provide some insight.
    Please Help DWW-700M
    Thanks so much!
    EvoX CarPC (in progress)
    Acer Aspire One, OpenPort 2.0 cable, 12V car power adapter, ignition timed relay to unused pins on Ethernet port
    Rhapsody, EcoScan, EcuFlash and still trying to make up my mind
    EvoVIII CarPC retired
  1. WTB: Lilliput Infared Opening Cover
    By hussein in forum Classified Archive
    Last Post: 10-20-2004, 01:52 AM
  2. Anybody use this from DWW
    By heartpumper in forum LCD/Display
    Last Post: 02-27-2004, 10:08 AM
  3. Can 7" touchscreen fit in double DIN opening?
    By RDaneel in forum LCD/Display
    Last Post: 02-26-2004, 02:53 PM
  4. New opening mp3car.com page
    By grandamp3 in forum Mp3car Forum Suggestions/Comments
    Last Post: 08-12-2003, 02:22 AM
  5. LCD Text Display for Din opening --Please Help...
    By prerunnerv6 in forum LCD/Display
    Last Post: 09-24-2002, 04:27 PM
