When the display gets powered the 1st and the 3rd line are black blocks.. that should be okay.. each one does that.. The display waits for the first command to show on the display..
If you are absolutely sure about your wiring, you may have to check your parallel-port setup in the BIOS, it should be something like EPP or SPP.
Make sure you specify the right adres with lcdprint. If you don't, the display doesn't show anything.
If you have done all this, and nothing works, I think the display is broken, but since it displays 2 lines of block when you power it that won't be the problem (I think)
Hope this helps you out, and let us know !
Greetz
LinkBack URL
About LinkBacks
