Results 1 to 5 of 5
Thread: All In Wonder 128 PCI Card
    Oct 2001
    England
    Post All In Wonder 128 PCI Card
    Could someone give me some advice before I buy this card.
    I'm looking to run Cobra 3 on a TFT screen. If the TFT screen is connected to the AIW 128 will it automatically output through the TV out option or does some ATI utility have to be run first. Basically does the AIW and TFT run without problems
    Thanks all
    telstaruk
    Maximum Bitrate Skippman's Avatar
    Mar 2002
    St. Louis, MO
    Post
    Your going to have to boot the computer once with a monitor connected to install the drivers and such and enable the TV Out support under Windows. After that you should have no problems.
    Stereo:Alpine IVA-D900 Head Unit | Alpine PXA-H510 DSP | Boston Pro Component Speakers Upfront | Boston Rally Rear Speakers | 2 Polk 10" Subs in the Trunk | Phoenix Gold Ti900.7 Amp
    Jul 2000
    Jackson, MS, USA
    Post
    on my all in wonder pro it automatically outputs to NTSC if i plug in something and then turn on the computer.
    24 y/o w/ Silver/Red
    2000 Honda S2000
    http://www.squeezer.net
    Nov 1999
    Ishoej, Denmark
    Post
    ATI, cards will enable your tvoutput by default.
    This means that as long as you are booting/running in dos the card will enable the output.
    However, if you have not enabled the tvout in your windows setup, the ati windows driver will disable the tvout when windows starts up.
    otherwise its like Skippman wrote enable the output and you should be up and running
    Oct 2001
    England
    Talking
    Thanks to you all, seems to be the card to go for
