Originally posted by Rob Heslop:
<STRONG>I've been reading around a bit on the net, ain't found much though.
Hacking the antenna off and sticking in a coax input will definately work. But it's crude (converting the signal to coax to convert it back again) and the picture will be pooh!
I be interested to see what happens if you just chuck a phono signalin. Pin 43 seems to be the one you want along with one of the grounds.
From what I gather pins 44 & 45 are the right and left
sound. You made need to loop 2 pins to trick it in to thinking that it's got a TV adaptor connected, not sure which ones though.
That's my view, but sorry if I'm way off.
Rob</STRONG>
