One of its features is that it will remember the last position of the monitor. So if it was open when you turned off your car, it will auto open the next time you start your car.
Armen
Originally Posted by therussman2002
Ive been researching the motorized displays (bought a 12" for the dash, and failed... into the trunk it goes), and I like the simple style of the MTSVO-SC the most.
Does anyone know if one of those wires on the back of these things causes it to auto-open from a controller or acc wire? I searched around mp3car/mp3car store/digitalww and I couldn't see the feature anywhere (though i'd imagine its a simple feature to have... I could just solder some wires to the button, but i'd rather it just came like that...)
Armen
thats fantabulous... Do you have some estimate when it is available at digitalww? I think mp3car store said july 15th
I don't want to put a solid date on the release but as soon as they will start shipping them out, I will have them.
Armen
They seem to be taking their time to filter out these ones.. could this be a good sign of making sure they are right or a bad sign that there is production problems...
Dont spose you know what the screen is Armen ?
Terran
The sample I have seems very solid so I am not sure what the delay could be.
I haven't taken it appart yet so I don't know. I will soon though...
Armen
Originally Posted by ccsnet
I got mine today. I will test it tomorrow. The manual is very basic and is actually useless.
On the back you find the following wires:
GND
12+
Accon
Park
Reverse
Remote
I wonder what the reverse and park do.
There are also AV1, AV2 and a reverse video input available.
Originally Posted by Partybuster
You should connect 'park' to the handbrake, so that the screen can only be used when the handbrake is on. But, if you want the screen to work nomatter the state of the handbrake, connect 'park' to ground (i.e. to the same place as you connect the black wire) - note that this might be illegal where you live
The 'reverse' wire is supposed to be connected to the reverse gear, in order to change the active input to the reverse signal - note that you cannot change to the reverse signal manually (using the 'src' button it only changes through VGA->AV1->AV2 and back again). I'm still trying to figure out just what it expects the reverse wire to be connected to, in order to be activated.
Oh, and I actually have no idea on what the remote wire does. The manual isn't at all clear on that one.
Yes, I though about that - but what I can get from the manual is, that it is supposed to be connected to a DVD changer. So I guess it's for giving a signal TO the screen when a DVD is played, so the screen changes to AV1 or AV2 - much like the reverse-wire. No sure though, will have to test both ideas.
