Results 1 to 10 of 18
Thread: Inversed LCD has brown background instead of black...
    Sep 2001
    Wink Inversed LCD has brown background instead of black...
    Arby, or anyone else, I have the Timeline 40x4 backlit LCD and I'm using the polarizing film from www.polarization.com. I rotated the film until it was a very dark purple and then I cut a piece and placed it in the LCD. I am using a 2 ohm resistor for the backlight because I couldn't find a potentiometer. When I turn on the LCD at night, the yellow text is very bright, but the background is a light brown behind it instead of black. Is this because I did not rotate the film correctly or could it be because I have the backlight turned up to its max brightness? Any help is appreciated.
    Jul 2001
    Post
    You might nt have rotated the film correctly, or it could just be the type of film it is....
    Sep 2001
    Post
    Well gee, such helpful advice.
    moahdib's Avatar
    Jul 2000
    Post
    The light backgroudn is NOT the film. I think it's bc the LCD backlight is at it's brightest. Mine is like that also...just turn down the brightness control if you got one and then you should get it completely black.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Sep 2001
    Post
    I've actually taken inversing to the next step...
    The film that comes attached to these LCDs is fairly poor quality. If you take the piece that came on the front, and cut it so you can test it against itself. You'll notice that it is impossible to make it opaque black.
    Also, the LCD glass has a certain ammount of polarizing properties, and it becomes impossible to get the film to show as dark as possible with the glass in between it.
    The film which I purchased from Arby was much higher quality, and I could get an almost opaque purple with the perfect ammount of rotation (of course it wasn't quite as dark when the glass was between it).
    I then realized that the piece of film on the BACK of the glass was also the same poor-quality stuff. I carefully removed this piece. I then cut the film which I received from Arby, and replaced both the FRONT and BACK. The result is a much darker display with nice bright characters.
    The only downfall is that I have noticed a slight inconsistency on the black background of some characters, but I don't know if this is related to the film or maybe some damage that was inflicted during the inversing operation.
    -Miles
    [ 11-05-2001: Message edited by: milesg ]
    Near Completion: Intel P166 MMX, 32MB ram, 13GB Hard Drive, Keypad, 4x40 LCD. Sproggy MK2.6 ATX PSU. Win98SE with Winamp and Mark Zehnder Plugin. (Web-site: very soon)
    Jul 2001
    Post
    So, it is the film??
    Sep 2001
    Post
    Well, it's a combo of the film that comes with the LCD and the polarizing properties of the glass.
    Upon re-assembly of my LCD with the "double-inversion", I've noticed some very odd artifacts on the display. I believe this is some kind of interference of each character space with the others adjacent to it when lit.
    Basically, I see a light flicker on text which is below the spectrum analyzer. It can make it very hard to read the other information, however, I believe that this is only an occurance which is now perceptible when viewing the panel with a high contrast setup like "invertion". I've returned my LCD to the un-inverted state, and these "artifacts" seemed to disappear
    My question is this:
    Do Arby's pre-inverted LCDs have this wierd flicker? and is a perfect opaque black inversion?
    I can't imagine that it is, since I purchased the same film that he uses (from him), and I can't even get a very dark black with both sides replaced.
    The pain is tremendous
    -Miles
    moahdib's Avatar
    Jul 2000
    Post
    All i have to say is that during daytime, inversed LCD's SUCK!!! I can barely see anything and the lcd turns into a purplish ugly color
    My TL CarPC ver2
    Sep 2001
    Post
    Well, after attaching a rheostat (same as potentiometer basically) to the LCD's backlight and turning it down, the background is still a brown color and not black. Has anyone found a polarizing film which will inverse an LCD's background to black yet leave the character parts nice and bright?
    Sep 2001
    Post
    It turned out that I had just clamped the front cover down too tight, and that was causing the wierd distortion... With the film I got from Arby on both side of the glass, I have an almost completely black background and nice bright characters... it's a kinda trickey process, but it's well worth it IMO
    Now I just need to get rid of these damn invered "P"s.
    -Miles
