Results 1 to 10 of 13
Thread: Xenarc and extreme tempatures
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Question Xenarc and extreme tempatures
    Hello,
    Im new to the forums and I gotta say, you guys rock!! I finally have a resource for my computer and car addictions. Anyway Im building a carPC and was looking into the Xenarc 7" touch screen. I live in Michigan and we see everything from 95 degress to 10 below in the winter. Im more worried about the cold than the heat. Im wondering if anyone has exposed the Xenarc unit to these extremes and if so the performance or lack there of under these conditions. Thanks for any help/reviews.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Well I live in miami beach...... and I have a xenarc, the screen works fine.
    BTW i'm running 2 40mm fans in the back.
    Good luck with you new project.
    Thanatos
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Nov 2004
    Hey how did you wire up you 2x 40mm fans in you LCD Screen?
    I just got one of those HD coolers and put the fans in the back of the screen (they are screw to the screen bracket) and then I just use the acc line to get power.
    Ok .... cheeckz185??
    Any other question please use the threads...
    Thanks.
    Thanatos
    Nissan Aux-in MOD
    Apr 2005
    Queens, New York
    so u basically just removed the HDD fans and mounted them to the back of the LCD?
    Nov 2004
    yeap.....
    Nissan Aux-in MOD
    Apr 2005
    Queens, New York
    you put them where the speakers are on the lcd? and were you able to put the backing of the LCD back on?
    Nov 2004
    no inside............ out side the screen!!!!!! I never open my screen and I think I never will..
    Nissan Aux-in MOD
    Apr 2005
    Queens, New York
    gotcha!
    Apr 2005
    Falls Church, VA
    I just installed my xenarc last week and am dealing with the hot temperatures here in Boston. What I've experienced is that the screen will not work at hot temperatures, either fails to display any image or displayes a garbaged one if any. Once the screen has cooled down via air conditioning, being put in the fridge, or whatever, it returns to normal operation.
    I'm sure heating it and cooling it isn't good for it, but I haven't found a good alternative yet.
    Aux
    PCChips M789 v3 w/ Samuel 2000+ S3Vid Lan AC97, 40 GB 7200PRM, 512 DDR266, Xenarc 700YV, PAC AAI-GM9 Headunit Adapter, Sirius Sportster, touchpad mouse input.
    Apr 2005
    Queens, New York
    What about just turning up the AC?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  1. Extreme Newbie to Carputers
    By TheLadiesMan in forum Newbie
    Last Post: 01-08-2005, 01:06 PM
  2. Xenarc 700TSV 800x480 Support
    By auto_robotics in forum LCD/Display
    Last Post: 08-27-2004, 01:33 PM
