Results 1 to 10 of 13
Thread: 4x20 problems...ergh
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    Angry 4x20 problems...ergh
    First off, I searched past messages for this problem to no avail..
    All right, turned out that hat 4x20 L2014 I got from was EIO.com was defective...which is very rare, according to them...but since the guys over at eio rock SO hard, they sent me a replacement for free.
    So I hooked it up using the schematics on their site, I even got the two rows of blocks (which means everything is hooked up right..woohoo!)...
    I used lcdprint.exe to check the lcd...lcdprint 378 shows:
    Standard Parallel Port detected
    BPP Mode supported
    LCD panel detected.
    "lcdprint 378 4 20 test.txt" which just kicks me back to the command prompt with no other comments on screen...(which I take to mean it worked.. or it thinks it worked..)
    But I get NO change on the solid bars of blocks...any thoughts?
    1999 Plymouth Voyager (That's right, big-pimpin' in a minivan.)
    PC built into console
    worklog with pics: http://www.mp3car.com/vbulletin/worklogs/46359-1999-plymouth-voyager-computer-in-console-between-seats.html
    Some of my music: http://www.myspace.com/markquestion
    Variable Bitrate peter3's Avatar
    Feb 2001
    The Netherlands (deventer)
    Post
    Make sure the test.txt is next to the lcdprint.exe
    In holland we mean in the same "map" don't know in English
    must be something like this:
    C:\lcdprint.exe
    and for the text goes the same
    C:\test.txt
    they must be in the same Directory
    Peter3
    PETER - THE NETHERLANDS - DEVENTER
    sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
    Sep 2001
    Post
    Also, only test it with a windows 9x machine... I don't know about WinMe though. Anything NT based shouldn't allow communication through the ports.
    -Miles
    Near Completion: Intel P166 MMX, 32MB ram, 13GB Hard Drive, Keypad, 4x40 LCD. Sproggy MK2.6 ATX PSU. Win98SE with Winamp and Mark Zehnder Plugin. (Web-site: very soon)
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Post
    This may be plainly obvious, but "test.txt" actually has to have text in it.
    I hope you already knew that...
    Jan 2001
    Austin, TX
    Post
    Heh, thanks for the help, but its a Windows 98 machine, the test.txt does have text in it, and it is in the same directory.
    Any other ideas?
    worklog with pics: http://www.mp3car.com/vbulletin/showthread.php?t=46359
    Mar 2001
    Perth, Australia
    Post
    change the parrallel port to ECP mode in the bios
    moahdib's Avatar
    Jul 2000
    Post
    I recently replaced the matrix orbital 20X4 LCD with the same LCD you got from eio and I got it to work without problems, I think your bios setting is wrong too.. make sure it's ECP and the command of lcdprint should be:
    lcdprint 378 20 4 text.txt, and not 4 20 like you typed.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Jan 2001
    Austin, TX
    Post
    Nope...I have it set for ECP..and the same thing happens if I switch the 20 and 4.
    I just can't figure it out because it *knows* the lcd is there and *thinks* it is sending output to it...but it's not. ergh.
    moahdib's Avatar
    Jul 2000
    Post
    I think you messed up your wiring man... other than that you might wanna try another computer.
    My TL CarPC ver2
    Jan 2001
    Austin, TX
    Post
    HALLELUJAH!!!!
    Remember boys and girls, no matter how many times you check your wiring, check it again. Corrected *ONE* connection that was loose...and voila: The world is right again.
    Stupid Radio Shack soldering iron. heh.
